DRAG RADIALS WHAT SIZE RIMS
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
IM THINKING ABOUT BUYING 18 " RIMS CAN I GET AN EXTRA PAIR OF REAR RIMS TO MOUNT DRAG RADIALS ON SO THEY MATCH
Engine: l98 tpi
Axle/Gears: 2.77
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: DRAG RADIALS WHAT SIZE RIMS
If you can 15’s money better spent.
else just run drag radials on 18’s all the time as your normal tire
Car: '89 Firebird
Engine: 7.0L
Engine: l98 tpi
Axle/Gears: 2.77
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Engine: l98 tpi
Axle/Gears: 2.77
Engine: l98 tpi
Axle/Gears: 2.77
the drag radials . how good are they in turns . lets say i wanna run them all the time . will they be good on the turns . i drive alot of back roads
Car: '89 Firebird
Engine: 7.0L
All I've had are low profile drag radials with a stiff autocross style suspension. Those feel fine cruising, but if you take a corner too fast it is like driving on a half flat tire. Rain is really sketchy. It's really a track tire with a DOT stamp (not a street tire that can be used at the track) so the sidewall cuts real easy. Not a good idea unless you're on smooth, clean roads. The tires overheat real fast so you can't drive high speed (if you're that kind of nut), only good for a quick sprint and hit the brakes (like a 1/4 mile track).
My experience is the drag radial works good at first but street driving ruins the tire. The rubber dries out and is never the same again. I get about 500 fun miles from a tire before that happens. Then the tire spins and that causes the rubber to feather and ball up and traction goes to ****. I can flip the tires and clean them up with a real quick burnout, but it only fixes things for a few days. My tires are destroyed by 1K miles. I've tried 3 brands now (Nitto, Mickey Thompson, M&H).
So.... I think the key is to not spin on the street and the tire lasts a whole lot longer. A drag radial is a "dead hook" tire and doesn't like to spin. That's an easy affair with an auto trans, but not so easy with a manual trans. The tendencies of a manual trans to spin the tires really accelerates the tread wear problems I described earlier.
Car: '89 Firebird
Engine: 7.0L
Just to add to that, I spend about half the summer with good traction and half the summer with bad traction. I've grown tired of the latter. I think next year I'm hanging up the drag radials and installing a 100 tread wear performance tire. I'll have better traction than I do now (end of summer) and I'll be able to corner again! I don't know, maybe I'll come back to the garage crying for my drag radials, but there's no way to know unless I just try stuff.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I am constantly swapping my wheels every few weeks depending on what events I am using the car for. I have Nitto 555 street tires on my fancy 18" Boze Forged wheels for car shows and autocross events. Then i have Mickey Thompson ET Street SS drag radials on my old 16" iroc z wheels for drag racing events. They do get balled up from street driving. I drive to and from the track with them , and I put about 35 psi in them for street driving because I carry hundreds of pounds of tools, spare parts, and gear to/from the track with me. I probably should lower them for street traveling, but at the track I run 19-20 psi and they hook.
For my usual 18" wheels that currently have the nitto 555 on them, I think i want to go with a sticker tire with better treadwear when i am due for new tires. the nittos are 5 years old and a 300 treadwear. My possible choices are the BFG Rival S, Toyo R888, or the newly released Falken Azenis rt660.
Engine: l98 tpi
Axle/Gears: 2.77
Engine: l98 tpi
Axle/Gears: 2.77
whats a good 15 " drag radial .
steven72192
Exterior Parts for Sale
May 31, 2013 05:49 PM
