Billet Specialties Wheels 15x10
Old 06-14-2021, 11:18 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s480
Transmission: Built 4L80e Circle D converter
Axle/Gears: 35 spline 3.25 gears
Hey guys has anybody has 5 any luck fitting a set of 15x10 5.5" BS single beadlock street lite wheels with LS1 rear brakes?? If no dice on those I guess I could always go for the 17" version and be done with it. Thanks.
Old 11-22-2021, 07:34 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: Billet Specialties Wheels 15x10
https://www.thirdgen.org/forums/whee...5x10-17x7.html
Old 11-22-2021, 10:51 PM
thatsupnow's Avatar
Originally Posted by irishhockey34
Nice so they will work. So I wonder since I've got stock 3rd gen width on my MWC 9" would a 5.5" backspace work just fine? Or maybe a 6" bs??
Old 11-24-2021, 11:25 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
i believe most 3rd gen width rear's use a 5.5" backspace on a 15x10. you can double check fitment charts from Weld to be sure. I had to cut out the bumpstops and get fully adjustable rear control arms and panhard to get the rear axle centered to stop the rubbing with 275/60s
Old 11-24-2021, 10:45 PM
thatsupnow's Avatar
Awesome thanks for the info!! Cutting the bump stops is no problemo and I've got an on car adjustable panhard bar
Old 11-26-2021, 05:25 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Last I remember 5.5 puts the wheel even with the fender lip, if you want the wheels inside the fender you need 6.5BS on a 15x10
I run a 15x10 with 6.5BS and had to cut the bump stops out and trim/massage the front fender wheel wells, I also have a Moser 9" standard length, UMI non adjustable control arms and an adjustable pan hard bar and everything fits no problem.
Old 11-26-2021, 10:10 AM
thatsupnow's Avatar
Awesome! Thank you sir
WTR388
Wheels and Tires
07-07-2020 06:56 PM
82Firebird5.0
Wheels and Tires
03-30-2020 12:16 AM
87350IROC
Wheels and Tires
124
07-27-2018 09:34 PM
pheonix305
01-23-2004 12:06 AM
Joe91Z28
08-20-2001 06:30 PM
Quick Reply: Billet Specialties Wheels 15x10
