Recommended lug nuts for CTW wheels
Old Mar 17, 2023 | 11:01 AM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
I just purchased a set of wheels from CTW this week. For those that own them, what lugs are you running?
Sean (who was absolutely wonderful to work with) said they use OEM 4th gen lugs on their race car.
I just wanted to see what other CTW customers might be using before I buy. Thanks in advance.
Old Mar 17, 2023 | 11:30 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Recommended lug nuts for CTW wheels
OEM lugs are more than adequate.
Old Mar 17, 2023 | 01:11 PM
russ89gta's Avatar
Engine: tpi 5.7
Is there any particular year of 4th gen style I should be looking at?
Old Mar 17, 2023 | 01:32 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Pretty sure they were all the same.
Old Mar 17, 2023 | 02:50 PM
russ89gta's Avatar
Engine: tpi 5.7
Thanks for the advice. I’ll work on getting some.
Old Mar 17, 2023 | 03:56 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The Gorilla open end style with knurl grips is really nice. 3rd and 4th gen both use M12-1.5 with conical seats. I'm not sure what was the stock hex head size, but my aftermarket lug nuts are 19 mm hex. I would not go any larger hex size than that or the socket might rub the wheel.
I have a full set of Gorilla closed end I'm selling for cheap, but it's probably not nice enough for your brand spanking new wheels.
https://www.thirdgen.org/forums/engi...-lug-nuts.html
Old Mar 17, 2023 | 04:32 PM
russ89gta's Avatar
Engine: tpi 5.7
Thanks for the feedback! I’ll check on some of those. I guess I’ll go new since the wheels are 😁
Old Mar 17, 2023 | 05:05 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Whatever you do avoid the anodized stuff. The finish get ruined immediately.
Old Mar 17, 2023 | 10:21 PM
BadSS's Avatar
I bought a set of the SLP 3rd Gen specific 17" x 8" ZR1 wheels years ago and needed something that used a thin wall socket. I can't speak for the quality of them now, but the West Coast Wheel Accessories I bought back then have held up nicely over the years.
$27.99 for 20
https://www.summitracing.com/parts/wca-w55015s
These appear to be the same lug nuts under the Cal Customs brand, in fact this is the part number I bought - for $4 more they come with some decent regular length chromed pull through valve stems.
https://www.summitracing.com/parts/cal-7555015s
Old Mar 18, 2023 | 01:10 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Incorrect, you cannot use factory lugs with CTW wheels, the lug pocket is too small. You will need a smaller diameter lug, I recommend spline drive lugs.
Old Mar 19, 2023 | 12:00 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What diameter can it accommodate, Paul?
I know you don't own CTW any more but all that stuff is probably forever etched in your memory.
Old Mar 19, 2023 | 04:27 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I like these lug nuts as they only require a 17mm socket
These are good for the street
https://www.ebay.com/itm/29549189088...Bk9SR7bI2ZLfYQ
and these are great at the track
https://5xracing.com/i-8580170-5x-ra...category:95122
just_another_rs
Wheels and Tires
Sep 7, 2009 10:53 PM
Keith5
Feb 10, 2002 01:04 PM
lostangel
Sep 21, 2001 02:35 PM
