2.8 mpfi pictures
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
2.8 mpfi pictures
i was looking at pictures of a 2.8 and for some reason, it didn't quite look like mine. i was wondering if you guys could post some pics of your 2.8's from different angles. thanks
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
mine looks the same
I have an 89 with 2.8 mpfi, it looks exactly the same as yours as far as I'm concerned. If you want I can take pictures, but I won't be able to till this weekend.
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Do you notice a big difference with the K&N filter and the way you set it up from the stock one? Not trying to change subject, just wondering. Thanks
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Engine: 2.8 Lt
Transmission: 5 Spd
Nice. Mine has like no power but it does when its cold so I think its a big lack of air. You said there a big diff with just the K&N filter hooked staright to the maf? I was going to see if I could reg up a regular filter for the time being. What do you recommand
Engine: '93 LT1
those pics look like mine, but the one that i saw was slanted downward from front to back...it's radiator was also slanted to where the bottom was closer to the engine. have any of you ever ran across this before, or do you think that it was a custom job?
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Originally posted by RTFC
I figured I'd throw a wrench into the mix
My engine looks the same pretty much.
Car: IROC Z
Engine: 5.7
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Never had a smog pump. From looking in the shop manuals it seems that only Manual trans got a smog pump in '87, mines an auto. My '88 firebird was an auto and it had a smog pump. Maybe they added the smog pump to everything in '88?
Linson
Sep 21, 2015 01:08 PM
