2.8 mpfi pictures
Old Feb 10, 2005 | 09:43 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
2.8 mpfi pictures
i was looking at pictures of a 2.8 and for some reason, it didn't quite look like mine. i was wondering if you guys could post some pics of your 2.8's from different angles. thanks
Old Feb 10, 2005 | 10:33 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Old Feb 10, 2005 | 11:58 AM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
mine looks the same
I have an 89 with 2.8 mpfi, it looks exactly the same as yours as far as I'm concerned. If you want I can take pictures, but I won't be able to till this weekend.
Old Feb 10, 2005 | 09:17 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
my '87
Old Feb 11, 2005 | 12:37 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I figured I'd throw a wrench into the mix
Attached Thumbnails 2.8 mpfi pictures-c-documents-settings-office
Old Feb 11, 2005 | 12:52 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
What's different about it?
here are the only two I could find....
Old Feb 11, 2005 | 01:18 AM
Car: IROC Z
Engine: 5.7
i bet the one he saw was carbed
Old Feb 11, 2005 | 07:12 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Do you notice a big difference with the K&N filter and the way you set it up from the stock one? Not trying to change subject, just wondering. Thanks
Old Feb 11, 2005 | 09:20 AM
305q_ta86's Avatar
Transmission: 5 spd
Actually, yeah. And combind with the headlights up, it was a noticeable difference. I also designed a PVC pipe piece to replace the part between the MAF and the TB, but it actually didnt make much of a difference. But the best thing you can do to one of these v6's is to give it more air.
Old Feb 11, 2005 | 11:41 AM
Engine: 2.8 Lt
Transmission: 5 Spd
Nice. Mine has like no power but it does when its cold so I think its a big lack of air. You said there a big diff with just the K&N filter hooked staright to the maf? I was going to see if I could reg up a regular filter for the time being. What do you recommand
Old Feb 11, 2005 | 12:17 PM
eagle_eyes's Avatar
Engine: '93 LT1
those pics look like mine, but the one that i saw was slanted downward from front to back...it's radiator was also slanted to where the bottom was closer to the engine. have any of you ever ran across this before, or do you think that it was a custom job?
Old Feb 11, 2005 | 01:06 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Hmmm, I've seen that plenum before.
My engine looks the same pretty much.
Old Feb 18, 2005 | 02:20 PM
Car: IROC Z
Engine: 5.7
sounds like the 2.8 from a front wheel drive beretta or corsica
Old Mar 7, 2005 | 10:55 PM
Pajaro De Fuego's Avatar
Car: 1989 Firebird SSA
Engine: 2.8L V6
Transmission: The stock one...lol
bru333 do you have your smog pump removed? My engine looks sort of like that...
Old Mar 8, 2005 | 08:16 AM
bru333's Avatar
Car: 1987 Camaro SC
Never had a smog pump. From looking in the shop manuals it seems that only Manual trans got a smog pump in '87, mines an auto. My '88 firebird was an auto and it had a smog pump. Maybe they added the smog pump to everything in '88?
Old Mar 20, 2005 | 05:50 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
This was mine the day I bought it. Slightly diffrent under hood now but virtually same
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
snakeshooter
Sep 7, 2015 11:13 AM
Strick1
Sep 6, 2015 02:21 PM
rjcme
Sep 5, 2015 01:23 PM
