upgrading driveshaft
Old Aug 14, 2003 | 09:16 PM
PsychoGTA's Avatar
My driveshaft just went out. And I need to get a new one. I got a 92 GTA w/350 auto, and stock rearend. What kind of driveshaft would you guys suggest for me to get. I wand to get a better one then the alumin shaft.
Thanx,
PsychoGTA:lala:
Old Aug 15, 2003 | 01:13 PM
MdFormula350's Avatar
you could try and bigger diameter ls1 aluminum driveshaft.
ebay has a few of them for sale right now.
Old Aug 15, 2003 | 01:44 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
you can order a carbon fiber driveshaft....if you got $800 bucks to blow.
http://www.thunderracing.com/index.c...yid=1015#T1020
Old Aug 15, 2003 | 04:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A friend used a stock aluminum third gen shaft in a 10.70s uncorrected 3500lb pro-shifted hemi4spd 477 rat powered car w/ a Dana 60 and it never failed.
On the flip side, some of the 4th gen f-body guys are breaking the stock aluminum shafts, sometimes in the middle; looks like tubing failure, which leads to...
I can't remember the forum, just that it was GM based, but I once read a pretty good discussion on driveshafts. Someone had found that an economically priced aluminum Ford Motorsport shaft worked in their car lengthwise w/ the trans. they wanted to go with. However, it was also thinner wall thickness tubing than aftermarket aluminum shafts.
So, I'd go with a quality aftermarket aluminum shaft and forget about it. That's what I did and w/ 3.73s it's quite smooth at speed. The more gear you're running, the more critical the shaft straightness & balance are. Cars with 2.73s can get by with a sloppy driveshaft far more than a car with 3.73s. That's part of the reason a car with some rear gear will get a thicker shaft from the factory; less flex with the higher driveshaft rpm that come with the numerically higher gearset.
If you're going to beat the ever loving dogcrap out of the driveline, like running 11s with a stick, I'd consider aftermarket steel.
Old Aug 15, 2003 | 05:14 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I went with the Inland Empire aluminum piece. $360 from Summit (part # IED-CF8200).
-Schultzy
Old Aug 15, 2003 | 11:53 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Is there really a noticable difference in driveshafts?
Old Aug 16, 2003 | 08:58 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I am using a Heavy Duty steel driveshaft from Denny's Driveshafts. It is a bit heavier than aluminum, but I was surprised that it weighs a little as it does. Like the guy said earlier, go with a quality aftermarket piece and forget about it...
BTW, we put my stock aluminum shaft into another car that had a stock steel on just to see if we could tell a difference. Yes, it was subtle, but there. The car just seemed to rev a bit faster. My friend swears his gas mileage increased, but I have my doubts about that...
I wanted carbon fiber but my money tree hadn't started to bloom yet...
Old Aug 16, 2003 | 09:37 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I chose the 1LE shaft. Even tho its .25" dia smaller then the LS1 shafts, it has thicker walls then the LS1 shaft. Lingenfelter has a 3.5" shaft that sometimes can be had on 4th gen GPs for a good price.
Old Aug 17, 2003 | 06:00 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Stock GM aluminum drive shaft dia's.
1LE = 2 3/4" dia
LT1 = 3" dia
LS1 = 2 3/4" dia
Old Aug 17, 2003 | 03:13 PM
1LE = 2 3/4" dia
LT1 = 3" dia
LS1 = 2 3/4" dia
The Al LS1 shaft is 3"
Old Aug 17, 2003 | 04:47 PM
DJP87Z28's Avatar
You better check again, the LS1 Aluminum dr shaft is the same dia as the 1LE and its 2 3/4" Dia. I was proved wrong about it myself.
Old Aug 18, 2003 | 05:41 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
I purchased a LS1 drive shaft from gmpartsdirect.com and was 3 inches.
Linson
Oct 24, 2025 02:00 PM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
Zell1luk
Sep 29, 2015 10:36 AM
apie2546
Sep 20, 2015 01:03 PM
