1le Suspension Bushing Part Numbers???
Old Aug 31, 2001 | 10:27 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I would like to change all my suspension bushings and sway bar bushings over to 1le. Does any body know the GM part numbers?
thanks
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
Old Sep 1, 2001 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 1LE 36 mm front and 24 mm rear bushings are as follows: 14094389 and 10037104. The poly end links are 10221779.
JamesC
Old Sep 3, 2001 | 08:44 PM
Cool thanks for the info. How about the front and rear control arm bushings? Do 1LE's have diferent ones then the WS6. If so, can I get those part numbers to.
'91 Formula
383CI Supercharged
5-speed
3.42
on Drag Radials
Old Sep 4, 2001 | 06:25 AM
JamesC's Avatar
I believe the LCA bushings were, like the sway bar bushings, a higher durometer rubber, but beyond that, I can't be of help.
JamesC
Old Sep 4, 2001 | 12:26 PM
98_1LE's Avatar
As far as I can tell, thirdgen 1LE's used most of the same suspension components as the WS6 cars, which your car already has. That being said and assumed try, GM does not sell just the bushings for the LCA's seperately, they only sell the assembled arm. Try 10164151 for the rear LCA, it's a fourthgen part # but is a direct bolt in to the thirdgen. SLP sells them cheaper than GM does.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Sep 5, 2001 | 06:47 AM
Thanks 98_1le, I have those control arm now on order. My next question is what about the front control arms. Did they use the WS6 front control arm bushings in the 1LE?
'91 Formula
383CI Supercharged
5-speed
3.42
on Drag Radials
Old Sep 21, 2001 | 10:21 PM
<font face="Verdana, Arial" size="2">Originally posted by JamesC:
JamesC
</font>
The swaybar bushings are not always 36mm front and 24mm rear for the WS6, as stated in the sales books. I actually measured mine and they are 34mm front and 23mm rear. What might be the GM part numbers for these? Another question is, what's the actual size of the 1LE bars?
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
Old Sep 22, 2001 | 05:50 PM
JamesC's Avatar
The hollow 1LE front stabilzer bar is 36 mm--GM part # 14094344. The rear is 24 mm, GM part # 10035033. These were on some, but not all, Camaros from 89-92 and on some, but not all, Firebirds, 86-92. I'm afraid I have no part #s for the smaller bars.
JamesC
Old Oct 15, 2001 | 06:55 AM
I just measured my front bar, where the bushings are, with a caliper. It measures 1.41" or 36mm. I guess I'll order the 36mm bushing p/n you gave above. I also found out there was never a 23mm rear bar on a third gen. I bet if I pull down that bar it will measure 24mm. Thanks
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
[This message has been edited by '91 Formula (edited October 15, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
