Problem solved on Dakota Digital SGI-5 install...
Old 08-01-2002, 12:28 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
I solved my problem with my SGI-5 on my T56 swap. I thought this info might be useful to someone else. I have a '89 Firebird TPI so it came factory with the electronic speedo.
My problem was when the car was idling, the speedo would pick up interference and read anywhere from 20 - 125 mph!!!!! I tired twisting the signal wires from the transmission like the instructions said, but that didn't fix a thing. After a couple of phone calls to Dakota Dig. and some testing, I realized that my interference was being picked up on the 12 volt power wire that goes to the SGI-5. I was getting my power source from my radio harness. I don't have a radio in the car. When I ran a wire directly from the battery to the SGI-5 all the interference went away. Don't ask me why this fixed the problem, cause I don't know. It may have something to to with my Accell coil.
Good luck,
Old 08-02-2002, 07:50 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Good info, I'm in the process and hope not to run into much trouble with the speedo stuff....
Can I ask what gears you are running and how you set your switches and what 'outs' you used?
Maybe an electrolitic capacitor on the power wire to ground would help get rid of any interference. Just a thought...
Old 08-02-2002, 11:03 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I used power from a thick brown wire by the vent/AC controls...no problems there. My box is located under my console.
Old 08-03-2002, 01:09 AM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
I'm using 3.42 gears. I also used Out 3. Out 4 did not work. Switches 1 & 2 need to be off. Offhand I don't know how 3 - 10 are set. Just drive next to someone, note the difference in speed and use the calculation in the instructions.
I'm not sure how the capacitor would work. I don't have that specific of knowledge in that area.
james_85Z28, do you have a stock ignition coil?????
Tom
Old 08-03-2002, 11:10 AM
Engine: 3.6L
right now I'm running off the stock HEI setup. My MSD is disconnected for the time being.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
middian
09-05-2015 01:42 AM
andy74
09-03-2015 08:41 AM
Jackrabbit501
09-02-2015 09:14 PM
greenyone
09-02-2015 03:39 PM
Quick Reply: Problem solved on Dakota Digital SGI-5 install...
