should i remove EGR?
Old May 20, 2004 | 05:26 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
im about to buy a custom chip and they ask me if i delete my egr. should i?? if yes how? what else is very stupid and the need to know??
Old May 20, 2004 | 07:27 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Leave the EGR in place. Its not doing anything and it actually helps prevent detonation given the way the timing is set up to work with it. The "tuner" that will probably do your chip will just disable the code for the egr and not really do anything about making adjustments to the timing and fuel thats necessary after the egr has been removed. Most of what you get is pretty much stock programming with a few small things changed.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
