9bolt torque arm same as 10bolt?
Old Sep 26, 2002 | 10:08 AM
formul8!!'s Avatar
Car: 2004 GTO
I am going to buy the Edelbrock torque arm. Their website states is a direct replacement for 10bolt arms.
Just want to make sure before I order.
Thanks!
Old Sep 26, 2002 | 03:36 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Yes they are the same. Are you buying an adjustable one I would recommend it.
Old Sep 27, 2002 | 02:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The Edelbrock non-adjustable torque arm fit my 10 bolt perfectly. It will, however, require modification for the 9 bolt (check my old posts for pics of the 9 bolt problems).
JamesC
Old Sep 27, 2002 | 06:39 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
On the back of the arm there's a square plate with an "E" in it, cut the E out and it'll fit on a 9 bolt.
Old Sep 28, 2002 | 08:19 AM
formul8!!'s Avatar
Car: 2004 GTO
How beefy of an arm is it? Is it any better than a stock arm?
Old Sep 28, 2002 | 08:25 AM
JamesC's Avatar
Here's mine (powder coated red--the orginal is black). Much beefier than the stamped stock version.
JamesC
Old Sep 28, 2002 | 11:24 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
we put a spohn adjustable one in my dad's car and the things pulls the wheels now. i would definetly suggest that one. it comes with a new tranny mount crossmember. the torque arm attaches to the crossmember as aposed to the back of the tranny so it is a at a fixed point as there is play in the back of the tranny. it is some what expensive ($400+ i think) but it is sooo worth it.
Old Oct 7, 2004 | 02:11 PM
Kandied91z's Avatar
i wouldn't trust the edlebrock versions...we had quite a few break out this way and the company won't reimburse you for a cent.
Kandied91z's Avatar
junk...
Old Oct 7, 2004 | 02:12 PM
Kandied91z's Avatar
do a search to read what happened, didn't even make it out of the shop lot and it snapped under light suspension load.
Old Oct 7, 2004 | 06:51 PM
CrazyHawaiian's Avatar
Car: too many ...
Why does your broken TQ arm look different than the one on JamesC's car? Same company but they look different. From looking at it I'm guessing yours was adjustable and James's one is not adjustable? If so, the non adjustable one looks much stronger.
Old Oct 7, 2004 | 08:07 PM
Kandied91z's Avatar
if by having a few triangular lines makes it look stronger then i suppose so...that's not the area of concern anyhow. why's it look different? can only assume they changed the design after a few years.....maybe someone can help you with that.
Old Oct 7, 2004 | 10:38 PM
Abubaca's Avatar
He's saying that maybe it's the "adjustable" portion that's got the weakness. JamesC's is not adjustable.
Old Oct 8, 2004 | 03:42 AM
Car: too many ...
Yeah look at the welds where it mounts to the rearend. Looks different to me. I guess I'll go find someone to "help me with this"
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
