Cam for LG4?
Old Feb 17, 2004 | 07:25 PM
87LG4FORMULA's Avatar
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
Cam for LG4?
I've got a stock LG4 in my bird with lots of $ in other mods right now. flowtech headers going on with 3" cat and cat back for later (next engine in a year or two) Meanwhile this motor needs some life and it is a roller block (centre bolt valve covers) so i was wondering if there was an easy way to cam this engine on a budget and without too much in the way of new parts? I am new to this stuff so speak slowly and i promise to get help before i wreck anything
Thanks, Tim
Old Feb 17, 2004 | 08:10 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
luckily your LG4 is an 87 so you have a roller cam
that makes things cheaper if you want to retain a roller cam
Old Feb 17, 2004 | 09:13 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
F-Bird'88 knows of a really great little roller cam that GM uses in their 383 truck engines. It was available from Competition Products for something like $40 brand new. That is a steal for a new roller cam.
PM him and find out which one it is. It has great numbers for a nicely modified 305, should give you lots of torque down low and a lot more hp up top
Old Feb 18, 2004 | 04:43 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
here's the cam
http://www.competitionproducts.com/page51.html
PN#264HP
If you have the "peanut cam in your 305 now this will help. will want some gear thou.
I also like the Cam in the Ramjet 350 crate motor.
Short(er) duration and higher lift than above.
But bigger and better than the lil cam you have now.
GMPN #
Camshaft: GM PN 14097395 hydraulic roller; 196/205 degrees duration at 0.050-inch tappet lift,
.431"/.451" w/1.5 rockers
0.460/0.481-inch lift (with 1.6:1 rockers)
More lift and area under the curve, should make good torque and power and maintain the low end grunt in a otherwise near stock LG4.
probabily should use LT4 style or better valve springs w/ 1.6 rockers.
Possible cheap source is GM Dealers that sell "upgraded" Crate Motors like Sallee Chevrolet or Pace Chevrolet.
They sell off lots of "take off parts"
Old Feb 18, 2004 | 05:09 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Is that competition products cam the same as the stock 350 tpi cam? Would that much lobe seperation on that cam kill bottom end torque on a carburated car?
91tealRS -how do you like your xr252 cam?
Old Apr 13, 2004 | 06:52 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
50 bucks, thats a steal.
anyone got any new info on the 264hp cam?
Brandon
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
