My TPI dyno numbers
Car: ws6
Engine: ls1
Transmission: m6
My TPI dyno numbers
Do these rear wheel horsepower numbers match the engine horsepower numbers?
245 rwhp=300hp at the engine?
255 rwhp = 310hp at the engine?
Thanks..........
Thanks..........
Car: ws6
Engine: ls1
Transmission: m6
Here are the mods,I have the dyno sheets too if anyone wants to see them.
FlowMaster Cat-Back w/high flow cats from Cat-co
EdelBrock TES Headers
EdelBrock High Flow TPI Intake Manifold
EdelBrock High Flow Intake Runners
EdelBrock Air Foil In Throttle Body
Throttle Body Bypass
TPI Intake Manifold and Runners Ported by TPIS
TPI Plenum Ported
TPIS Adjustable Fuel Pressure Regulator
TPIS- ECM Reprogrammable Chip
Gutten Air Box
K&N High Flow Air Filter
ACSD 82-92 Camaro IROC TurboHood
HyperTech Chip Stage One
HyperTech 160 Degree Thermostat
Re-mapped Injectors
MSN Ignition, Blaster Coil
Accel High Performance Rotor,Wires
Beefed up Alternator
Mass Air Flow Sensor [cut out fins]
ARP Engine Fastener Kit
Synthetic Motor Oil
3.42 Rear End
245/50/16 Radials
TPI Plenum Ported
Gutten Air Box
Re-mapped Injectors
Synthetic Motor Oil
3.42 Rear End
245/50/16 Radials
i think i've seen a dozen threads already of this guy posting the list of mods that were done to his car by the guy who sold him his car. he's always asking about what his power numbers are or should be or could be and 0-60 times or whatever.
give it up man, who cares what your flywheel hp is.
you got a dyno sheet and you ran at the track, those #'s are all that matter.
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Well if you are just curious then you already have your answer. Conventional wisdom 'estimates' drivetrain loss at 15% for manual cars and 20% for auto transmission cars. There are MANY factors that drive the actual loss (transmission, convertor if applicable, rear end) which is why it is an 'estimate'. IMO, I think that most get pretty liberal when determining what their drivetrain loss is (for example numbers start going north of 25% in order to prove a number that is in someones head). If you just want a big number to brag about assume a drivetrain loss of 65% and have a good time.
Your trap speed on a corrected timeslip is probably the best real world number to use to determine hp.
I would be very interested in seeing any dyno data that folks here may have from and engine dyno and then a chassis dyno with the same engine, same tune, etc.
-Schultzy
-Schultzy
Car: ws6
Engine: ls1
Transmission: m6
Ya I was curious what the percent loss was. I thought it was somewhere in the 15-25 percent area,just wanted to confirm it with the experts in here....If your intrested in the dyno sheets I will post them when I get some free time this week...
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
TPI Plenum Ported
Gutten Air Box
Re-mapped Injectors
Synthetic Motor Oil
3.42 Rear End
245/50/16 Radials
TPI Plenum Ported
Gutten Air Box
Re-mapped Injectors
Synthetic Motor Oil
3.42 Rear End
245/50/16 Radials
I ahve roughly the same setup but with a ZZ4 cam and SLP 1 3/4 headers I got 255 rwhp and 318 rwtq untunned
Car: ws6
Engine: ls1
Transmission: m6
My rwhp 245, rear wheel torque is 325, ill try to get the sheets up by thursday or so...What do you think of the ZZ4 cam?
Car: 1989 IROC-Z
EdelBrock High Flow Intake Runners.......
TPI Plenum Ported
TPI Plenum Ported
So is it a TPI manifold and runners or Edlebrock ? I am confused.
The ZZ4 cam works great for me . But I can really feal it die off up top
( 5000 ) but I am only lossing 20 hp from 4900 to 5600 rpm. But I could feal it for sure. I put in a set of 3.73's with it ...and around town its a real blast to drive ( 5 speed) . Good strong mid range. Joined: Sep 2003
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
edelbrock TPI stuff ported by TPIS
the TPIS bigmouth base is pretty much just what he did, a edelbrock casting ported out and TPIS name on it
Car: ws6
Engine: ls1
Transmission: m6
Car: ws6
Engine: ls1
Transmission: m6
Run 3-TPIS
Run 15- HT
Run 14-TPIS
Run 4-HT
Ran it twice with a Hypertech stage one,and twice with a TPIS reprogramable. The hypertech looks to make better power...
Run 15- HT
Run 14-TPIS
Run 4-HT
4750
4750
damn...I was wondering...usually horsepower and torque are equal at 5250 and I didn't see that, so I knew it was fairly low. 4750 isn't very high at all
Next time I get it dynoed should I rev it higher?
Car: ws6
Engine: ls1
Transmission: m6
I also have some timeslips as well. I got some from when the car was stock. If anyone is interested let me know.
Stock-14.8@94
All mods above with 2.77 gears. 13.8@97
3.42's 13.5@99
Stock-14.8@94
3.42's 13.5@99
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Not bad. The best that I've had so far is 253rwhp and 355 rwtq.. Neat thing about that is that I have a totally stock intake, heads, short block... The best time that I've gotten out if it is 13.7@103.16mph with a ****ty 60' and a fubar trans.
Car: ws6
Engine: ls1
Transmission: m6
Thats really good...I was thinking once I get more experience at the track my times should improve. The times with the 2.77's look about right. The 3.42 times should be lower...
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
