View Poll Results: Would you ever try foreign power in an f-body?
Yes
20.45%
No
35
79.55%
Voters: 44. You may not vote on this poll
SHO in Firebird
Old Sep 3, 2003 | 02:07 PM
sschoeffler's Avatar
SHO in Firebird
I just got an ultimate setup that will smoke an LS1. About a week ago I installed a 3.2 Liter DOHC V6 from a 94 Ford Taurus. Sounds week and feeble minded? Wrong. Ford didnt build this motor, Yamaha did...I have had it installed for a week now and damn she runs good. I raced a friend that had a 1995 LT1 Z28 and smoked him. Easy...from the line all the way to the end of the 1/4 mile. Heres what I did. Bought the motor from a salvage and put a twin turbo set up on it, running two TD05 turbochargers from a manual 1st gen Mitsubishi Eclipse. The car ran a 12.9 in the quarter, I can rev it to 7500 RPMs with no problems. The car gets 25 miles to the gallon on the highway. Very reliable car. So if ya can find some other way to have a fast/affordable/unique car, I would like to see it. I would say I am pushing about 420 HP. Also, it looks very nice under the hood of a black 96 Firebird.
Old Sep 3, 2003 | 02:12 PM
BADBIRD009's Avatar
that is wild!!! i personally HATE ford even though it is a yamaha its close enough for me, but that sounds like a powerful setup. my buddy has a sho its a pretty quick car. lets see some pics.
btw it is fwd right? how the heck did you do that?!?!
Old Sep 3, 2003 | 04:25 PM
OMINOUS_87's Avatar
Pics, we need to see this!
Old Sep 3, 2003 | 05:03 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Absolutely...post the pics....This I have to see...
Old Sep 3, 2003 | 05:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lots of spanking going on here.... That monkey black and blue yet?
Old Sep 3, 2003 | 05:54 PM
Engine: LS3
Transmission: 6L80E
A picture is worth a thousand words...
Old Sep 4, 2003 | 02:16 PM
David Petersen's Avatar
So what is the poll for?
Old Sep 4, 2003 | 03:07 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
is there even a rwd tranny that will hook up to the front wheel drive mtoor and make it rear,,,unless you made the firebird front wheel drive.....which if it was the case i feel sorry you spent the time figuring that out
Old Sep 4, 2003 | 04:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Old Sep 5, 2003 | 11:26 AM
Sorry guys, I am in Corpus Christi right now and I have limited access to the internet. I will get you all some pics in 3 or 4 days, whenever I get back to Yorktown and get the digi camera from my friend. As far as makin it a RWD vehical, heres what I did. First of all, I took some JB Weld and filled in the Ford emblem on the intake, sanded it smooth and painted it bright yellow(Me thinks Yellow and Black look awsome together) After that, I had to make some motor mounts. That was a pain in the *** since they had to be custom fabricated. Heres how I made them, I used a 1/4 inch thick steel plate for the mount bases, rear four link bushings, and 7/8 seamless steel tube to connect them together. Once I got the motor nice and tight, I started on the transmission. I used a T5 transmission used with a 87 Aerostar bellhousing. The bolt pattern was the same. Then I made an alluminum adapter plate to bolt the transmission to the bellhousing. It gets a lot more detailed, best thing to do is to give you the website address that I went to that will explain the whole thing.
http://www.shotimes.com/php-bin/modu...hold=0&sid=176
Anyway guys, I gotta get outta here. I will have some pics for ya in 4 days when I get back home and get the digital camera from my neighbor.
Stephen Schoeffler
Old Sep 5, 2003 | 04:53 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i've gotta see this.... just posting in order to get the email notification when he does post....
Old Sep 5, 2003 | 07:47 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
As a former '91 SHO owner I can contend to the potency of the Yamaha Engine.
I have also browsed the internet and there are MANY sites devoted to SHOS and the SHO engine swap. There IS even a AC Cobra Replica out there with the SHO power plant. It sure looks pretty facing north south.
Remember people you can make an adapter plate to mate any engine to any trans. Then all you need is the flywheel to bolt to the torque converter or clutch... not an undaunting task.
The bi-turbo AND 25 MPG is a bit of a stretch.. but money can buy just about anything. IF this guy did this all himself he is one hell of a fabricator / tuner.
The proof however IS in the pudding. Pics man pics... and don't try pulling any photoshop BS
Old Sep 6, 2003 | 02:27 AM
OMINOUS_87's Avatar
Publish or perish! Right now everyone thinks he is a liar, I would love to see him prove us wrong.
Old Sep 6, 2003 | 06:59 PM
Guest
Guest
Posts: n/a
i'm just posting so i can get an update via E-mail when and IF he will post the pics
Old Sep 7, 2003 | 10:59 AM
85_ZED28's Avatar
Car: '85 Z28
must...see...pics!
Old Sep 7, 2003 | 11:04 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
no pics and no pics make tim go something, something, crazy?, dont mind if i do...
Old Sep 8, 2003 | 06:06 AM
Dr G's Avatar
Schoeffler,
Are you back in Yorktown yet to take and post the pics? If you are then we all would like to see the pics and give you the well deserved respect.
Old Sep 8, 2003 | 09:49 AM
Guest
Guest
Posts: n/a
Am I going to have to lock this, or can we keep the .02 to ourselves for now?
I at least want to give him a chance to post some pics of this creation.
Old Sep 9, 2003 | 06:51 AM
conlinj's Avatar
I would definatly like to see this
Old Sep 10, 2003 | 01:35 AM
bigals87z28's Avatar
Car: Check The Sig
ill ask the question i see no one else has...
WHY?!?!
Old Sep 11, 2003 | 11:04 AM
Actually heres the deal. I keep trying to post through hotmail and when I do that, it tells me I'm not logged in, so once I have a huge page typed and I press done, it screws up. Now secondly, Abird4u2nv1 - Its not a third gen car, its a fourth gen car, 1996 black Firebird. Also My last post that I tried to make, I was going to say that my buddy that has the camera is out on the Rig and will be back in like a week and a half. Alot of poeple in Yorktown work on oil rigs. So I am going to have to wait for him to get back. Anyway, if you like to call me a liar, go for it, It doesnt bother me that much, its just internet. What does hack me off is that it wasnt all that hard, yet you say its impossible. Anyhow, I will post the pics as soon as I am able to get them.
Stephen
P.S.
She is still running great.
Old Sep 11, 2003 | 11:17 AM
Briansz28's Avatar
That's a good start!
Steve- you can take a disposable camera, take shots and have Wal-Mart put the pics on a CD. It might go along way in putting this to rest quickly, and restoring your credibility.
Old Sep 11, 2003 | 11:22 AM
Ahh, I wasnt awar that Wal Mart did that. I guess I could make a trip to Wal Mart tomorrow or something. We dont have a Wal Mart in Yorktown. Oki, well then I can get some pics in like two or three days. Believe it or not, this is not at the top of my list. Anyhow, I'll stay in touch.
Stephen
Old Sep 11, 2003 | 11:27 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Stop posting useless garbage abird.
Old Sep 11, 2003 | 02:35 PM
Guest
Guest
Posts: n/a
No, I'm not closing it, this is staying open.
Unnecessary comments will be removed later today.
Old Sep 11, 2003 | 04:47 PM
OMINOUS_87's Avatar
sschoeffler
While we wait for the pics could you please entertain the crowd by detailing what engine management system you are using to control this hybrid?
Old Sep 11, 2003 | 05:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
my roomate has a SHO... we're building another SHO engine for it right now so he can swap... (its his daily driver so it cant be down for the entire build)
poking around you can find several swaps where they change the East-West layout to a proper RWD North-South one.. heck one guy even turned the engine around in his SHO and has it RWD lol.....
leaving out the turbo part and talking about just swapping in a SHO motor, i honestly dont think it would be that hard. what are you guys expecting to be hard about it? worse thing i can think of are the wiring for the gauge hookups... other then that, its a pretty straightforward (athough unusual) swap...
as for what EFI hes using, i donno... i dont know much about ford ECM setups, but i do know that a stock SHO has 3 computers.....for some strange reason.. heh
Old Sep 11, 2003 | 09:41 PM
Guest
Guest
Posts: n/a
Any more useless replies are gonna get deleted.
Old Sep 16, 2003 | 10:44 PM
irocNuff93's Avatar
its quit simple
I was nice, now I am not. Conisder yourself history.
Old Sep 16, 2003 | 11:12 PM
OMINOUS_87's Avatar
Read reply below.
Old Sep 16, 2003 | 11:27 PM
Guest
Guest
Posts: n/a
Sure are some stubborn people around here.
Anyone who chooses to reply to this thread with anything useless or derogatory can consider themselves warned. The second time will end up in probation. Third time is banned.
Going to leave this open to see how many people cant behave themselves.
Old Oct 13, 2005 | 10:14 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Im going to have to dig this one back up sorry guys
Did this really happen? I saw no pictures and a lot of chit talking, but are there any pics anywhere? Id like to see it
Old Oct 13, 2005 | 01:10 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
Thats a pretty interesting swap, a buddy of mine has a SHO it pulls pretty hard, but one thing you said you ran a 12.9 with turbo SHO engine, well doesnt LS1 3rd gen's run lower then that stock.
Justin
Old Oct 13, 2005 | 01:43 PM
Engine: 350 tpi
I wouldnt consider a ls1 powered 3rd gen stock...
But yeah you should be able to run 12's no problem in an ls1 3rd gen as long as you can find traction
Old Oct 13, 2005 | 01:56 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Who would want it anyway
Old Oct 13, 2005 | 02:09 PM
Engine: 350 tpi
Want what? A SHO powered firebird? i dunno just thought it was a cool idea, custom work and new ideas get me excited. FYI tho he did this swap in a 96 bird... which doesnt make much sense, a TT Lt1 should make much more power then this thing supposedly does... i would think it would be less work then this swap...
Old Oct 13, 2005 | 09:29 PM
5.0Camaro's Avatar
I was refering to the engine stock, i wouldn't consider the car stock.
Old Oct 13, 2005 | 09:37 PM
z28 NyC's Avatar
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
Ford/yamaha engine in a f-body?, iam not positive but iam pretty sure thats a sin
Old Oct 13, 2005 | 10:08 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
LOL
Old Oct 14, 2005 | 11:28 AM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Well, pretty nice, but isn't it easier, cheaper, and more powerful to just turbo a 350?
Some people fail to realize that you CAN turbo a V8...and it will rape most anything else...
Old Oct 14, 2005 | 11:29 AM
z28 NyC's Avatar
ok soo what made you decide to put this engine in your f-body you had soo many different options without goin foriegn, or that kinda money you could of keep it all american under the hood and had lots of power
Old Oct 14, 2005 | 05:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use the PM function.
Old Oct 24, 2005 | 12:46 AM
StephensGTA's Avatar
Car: 89 Formula Trans Am
Engine: Twin Turbo 350
No pics yet? We could settle this quick sschoeffler how about i meet up with you soon since i live about 20min from you in Kenedy Ill bring the digi cam snap some pics and then we could go heads up TT 350 vs. TT 3.2 l to see what that ford powered car could do. I dont doubt he did it that town of yorktown seems to spawn some really odd cars but none have been able to beat the BlownBird1 or 2 and im sure the soon to be 3. Not bashin the guy or trying to be almighty just wanna see some pics.
If you dont wanna run the TA ill bring the fiero powered by a pretty little caddy motor and its stock just name the time a place ill be happy to come to you. PM me when your ready.
Old Oct 25, 2005 | 11:59 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
haha no pics in over 2 years!!!! dare i say liar...would have been a cool swap tho. the tranny wouldnt handle 12.9's nor would the rear.
Old Oct 25, 2005 | 12:08 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I would like to see this my last car was an sho so i do have respect for the bullit proof 3.2 and 3.0 yamaha motor.
Old Oct 25, 2005 | 01:52 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea i love the SHO motors. my friend has a 89 and i love the car, thought about buying one. i really wanted to see this too...
Old Oct 27, 2005 | 01:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Wow I remember reading this and falling off the chair two years ago. To all those who dont know better I guess the oriiginal poster dident either. It's pure fNord crap under the intake & heads.
You would think by now we would have some pics some where.
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
