PA / Profab K member with Spohn arms ?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Anyone tried fitting the two together ?
From what I understand the stock A Arms wont bolt right up with the profab / pa k members, and the spohn a arms will bolt right into a stock K member.
Anyone know that the spohn arms will bolt right to a pa / profab K ?
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Are supposed to. I just got spohn arms today,am still waiting on k-member. Will post pics when I have everything together.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
looking at the pics online.... yes they would.
the spacing is identical to the stock pieces... its just that the stock pieces are so thick that they hit the crossbar.
steves looks exactly like theirs in that area, so they should work just fine.
Car: 85 z28
Engine: 94 lt1
I would have to guess they will bolt right up. I just installed the PA tubular a-arms on my car and they fit right in, so I would guess the other way should work too.
Am in the process of installing Spohn LCA's (finally). I have put them in without springs and they fit fine in PA k-member. The front of the arm is very close to the front cross tube in k-member as seen in pix.
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i have a PA crossmember with spohn A arms. it fits fine you just have to position it just the right way. i thought i had pics of them put together but i only have pics of the crossmember.
Car: 1990 Camaro RS
Mark,
Color and shape wise, they look like the Spohn Extreme Duty tie rod adjusters.
I believe they are hotchkiss...they are about 9 or 10 years old and purchased through either summit or jegs (under all the scum and overspray they are powdercoated red).
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I thought I might add this.
My profab K member and A- arms. I am not too worried about it, but its something to think about.
Car: 91 Camaro Vert
if the bolts for your tie rod adjuster faces inward, they make thoes scrape marks.... flip them around and they JUST clear.
Transmission: Th350
Ragtop Man
Sep 12, 2015 12:23 AM
