Tremec questions??
Old Feb 22, 2005 | 01:21 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Tremec questions??
Hey guys I am gonna be buying a tremec tko soon and I am just gonna go ahead and get the spohn crossmember/torque arm setup while im at it, Now In Fortes the trans in listed for $1975. Now is this just the trans and the playe to bolt it to the bellhousing?? Also does it come with a shifter?? and finally is there anywhere cheaper lol. thanks guys
Old Feb 22, 2005 | 05:05 PM
brutalform's Avatar
One thing to watch out for is, the 2 spacer blocks that they send with it. They are to go between the frame and crossmember. the TKO sits lower in a third gen than GM transmissions. I would ask Spohn if he has any thoughts on compatability.
The TKO comes with the fore mentioned spacer blocks, shifter, trans yoke, bell. adapter plate. You can order the backup light switch, and speedo gear...which is more money if it is electronic...Also you can adapt a different shift handle on the TKO shifter, as it will probably bump your stock console if you dont.
Mike, at Fortes does a fantastic job in customer service too. thats who I bought mine from.
Old Feb 22, 2005 | 06:09 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought mine from Forte's as well.
Like brutalform said above, their kit includes a bellhousing to trans adapter, spacers for the crossmember, oil, backup light switch, driveshaft yoke (Ford C-6 Type), adapter U-Joint and speedo adapter, (that costs a little more for electronic speedo).
If you get the Spohn crossmember, you won't need the spacers.
It comes with a shifter stub on the trans, you can bolt almost any stick to it (I re-used the Hurst Comp Plus stick from my T-5).
Best shifter is probably the Pro-5.0 for Tremec.
Not sure of any less expensive Tremec dealers, but Mike Forte was easy to deal with and seems to know what he's talking about.
-Rich-
Old Feb 22, 2005 | 10:46 PM
brutalform's Avatar
-Rich- [/B]
Ive tried the PRO-5.0, and I thought the better option was using the stick lever only from the 5.0, with the shifter the trans came with. This seemed to be the best alternative for me.
Old Feb 22, 2005 | 11:37 PM
Car: 89 Formula
Engine: Carbed 5.7
Well I have a pro 5.0 on my t-5 so I should be fine there, Now is the 1975 including all the spacers and brackets or is it just the trans and the adapter plate for the bellhousing?? The Spohn crossmember is all setup for the tremec so that should be fine.. Also form when you ordered it how long did it take to get and also does it come with wutever speedometer gears your specify??? thanks
Old Feb 22, 2005 | 11:56 PM
RWB____s's Avatar
Car: Z/28
Transmission: Turbo 400
I run a tremec in my car. DONT use the spacer blocks from Fortes.
You r best bet is to get the crossmember from Spohn. Its a direct bolt in with no mods to make it fit.
Old Feb 23, 2005 | 08:16 AM
brutalform's Avatar
Yes, you just wont be able to use the base of the pro 50. 2 allen bolts and the lever comes off.
I do believe the TKO is a couple hundred more than the 3550. You get the shifter w/o ****. The yoke is included too. The extras is the crossmember spacer kit, which is like $80.00. And the speedo gear adapter are like $100.00 if you have electronic. Less for cable speedo. The bell adapter is included as well, so is the hardware, fasteners etc.
If I remember correctly, about a week and a half for delivery.
Old Aug 29, 2005 | 08:59 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Bolt size/thread for t-5 trans to bellhousing bolts
Old Aug 29, 2005 | 09:10 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: Bolt size/thread for t-5 trans to bellhousing bolts
WHOOOPPSSS... Hit the wrong button.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
