AC Removal
Old Oct 29, 2003 | 11:08 AM
xmind2006's Avatar
Car: '86 Iroc-z28
AC Removal
Dumb question here, but where is the tech article about how to delete/remove the ac from my car? I don't need a dummy pulley since my car is an 86 correct?
Thanks.
Old Oct 30, 2003 | 08:23 PM
MdFormula350's Avatar
http://members.***.net/iroczdave1/IR...rts%20Page.htm
heaterbox you will need, its a simply bolt in mod and then some minor wirings
if u have the one belt setup for all stuff on the engine then u most likely should buy the a/c delete pulley.
with v-belt your right u wont need the a/c delete pulley.
i started in front buy getting the condensor out, thats in front of the radiator, just unbolt the top piece that holds the rad. in place and then unhook the a/c connections going to the condensor, then lean the radiator back to slowly get the condensor out, after that unbolt the compressor and lines going to and from the big a/c box.
there is plenty of info about a/c delete so some searching might help u out some more, but basically its a bolt out/bolt in case.
Old Oct 31, 2003 | 03:18 PM
iusedtobebrober's Avatar
Car: 1985 firebird
Engine: 2.8 173 v6
Transmission: The one it came with
i did this to my car, i was surprized as to how heavy the crap was.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
