Triangular Air Cleaner!
Old Jan 7, 2004 | 09:57 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I just got my Edelbrock Elite Series Triangular Air Cleaner in today it is absolutely great! It looks great and it fits really well. I put it on and everything fit great, except for one thing; it cleared all throttle linkages and the distributer WITHOUT the spacer, but the screw that you tighten the fastener on does not have enough threads on it to properly secure the lid. Im not sure if mine is the original or not, so yours MIGHT work. So to get around this problem Im going to get the smallest spacer I can find (1/4"). But I would very highly recommend getting one of these. Like I said, no problems fitting or clearing anything, except for that long screw, grr.
Old Jan 7, 2004 | 10:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Triangular Air Cleaner!
Try backing out the stud a bit. You can do that and have the lid close just fine because it raises it a bit. I did that with mine. You may have to unplug the injectors to get the angle of the stud to clear as you unscrew it but you should be able to get enough threads after that.
Old Jan 7, 2004 | 10:15 PM
25THRSS's Avatar
or you could get one off a tbi truck. They have taller elements and a longer stud.
Old Jan 7, 2004 | 10:25 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You learn something new everyday. I did not know that. Is that because their air cleaner assembly is different?
Old Jan 7, 2004 | 10:53 PM
25THRSS's Avatar
yeap, the trucks have a ton more room under the hood and their air cleaner is a lot taller.
Old Jan 7, 2004 | 11:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea I knew about the room but didn't about the air cleaner size. When you look under the hood it seems like you can change cams in 5 minutes without removing the radiator or anything. Seems like you can attach another motor in there. Hugeness...
Old Jan 7, 2004 | 11:16 PM
25THRSS's Avatar
haha yeap, i think i could sleep under the hood of my dad's truck. One trick you can do to an f body is to use the truck filter element and top it off with the stock air cleaner top to get an open element effect or you can use the truck top to seal it off and have a little more filter element. I believe a couple people here have done it before.
Old Jan 7, 2004 | 11:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You should see the space with the 4.3. You can do headers and a cam in like 4 minutes top. That is a good idea for a cheap mod with the open element. Because when you flip the lid on the stock piece it doesn't quite tighten down enough. The taller filter would allow that.
But if money and time is a factor try to unscrew the stud a bit.
Old Jan 8, 2004 | 10:08 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
All you need to do is go to any local tool shop (sears, ect.) and buy a threader. Make the threads go a lil' bit lower and that just saved you a huge headache. My $.02
Bruce (90RS305)
Old Jan 8, 2004 | 04:48 PM
Engine: L69
Transmission: A4
I have everything to make the threads longer, but there is a bend where the original threads stop, so thats why I cant elongate it
Old Jan 8, 2004 | 05:02 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
My flat base open element didn't fit either so I backed out that stud all the way and took it out. I put the stud in a vice and "changed" the angle of that bend in it to make it longer. It now fits perfect.
Old Jan 8, 2004 | 06:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Did you try to just unscrew it a bit out of the TBI unit. I still think this is your quickest fix. Happens to many people who change air cleaner assemblies.
Old Jan 8, 2004 | 09:33 PM
Engine: L69
Transmission: A4
I just got it on!!! Im not using any form of a spacer and it fits perfect. I took the stud out and fixed the threads enough to get it on (they are messed up). Tomorrow my dad is going to either get a new stud or get the tool to correct it. It turned out I didnt have to bend anything. But anywho, I took for a test drive and everything works great and I can actually accelerate past 4000 RPMs.
But I did have to rig something up for the crankcase filter. I cant find a push in that fits 3/4" so I took the stock metal tube, flipped it upside down, and put a longer rubber hose on it. It turned out to work great. And the only other thing Im gonna have to do is shorten the stud to get the screw to screw down enough; no biggy.
But all in all, this is MUCH EASIER than getting a round open air element. Like I said, no spacer of any kind, which should really help! PM me if anyone has any questions
Old Jan 8, 2004 | 09:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I just got it on!!!
Hey good job and glad to hear it is all working good for you.
Old Jan 8, 2004 | 10:09 PM
steve8586iroc's Avatar
Now all we need is a good clear picture of it on your car.
Steve
Old Jan 9, 2004 | 03:07 PM
Engine: L69
Transmission: A4
I really wish I could, but I dont have a digital camera But it looks better than a round one
Old Jan 14, 2004 | 04:26 AM
Redline's Avatar
Car: 88 camaro SC
Engine: 305 t.oilet b.owl i.njection
Transmission: rebuilt 700r4
i dunno if its true, but ive heard to be careful with the element inside that filter. if it gets dried out it will deteriorate and fall apart into your throttle body--not a good thing. i imagine it would take a while before this happens though
Old Jan 14, 2004 | 05:02 AM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
i wasnt gonna say this before, but if you mess with your timing, be careful for backfires! can you say OH SH**?! of course i dont have this prob anymore. that stuff happened in my early days.
Old Jan 14, 2004 | 09:02 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Hey redline he was talking about the one that is just a normal open element but shaped like a triangle. Looks like this.
Old Jan 14, 2004 | 09:08 AM
Car: 91 RS
Engine: LO3
ahh....i see. i thought he was talking about the pro-flo
Old Jan 22, 2004 | 08:28 PM
Engine: L69
Transmission: A4
Quick Update:
the car runs like a champ and I havnt had ANY problems what-so-ever! I highly recommend this air cleaner if you dont wanna go through the hassle of trying to get everything to fit correctly
Old Jan 25, 2004 | 11:21 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
well i bought the pro flow today and i got it on perfect and all on my 4bbl not tbi and i knew that it mgiht not fit i shut the hood it wouldnt close without force and pushed the back of the hood up a bit so im stuck with my ****ty 3 dollar cleaner now anyone got any sugestions ?? as you can see from the pic my hood comes down on this air filter too by how messed up it is ..... thanks in advanced if u answer need sugestions of what would work becides a new hood
Old Jan 26, 2004 | 12:31 AM
joshwilson3's Avatar
Old Jan 26, 2004 | 12:53 AM
90RS305's Avatar
I use the Edelbrock 14"x3" drop base aircleaner in my car and it fits perfectly. No hood issues, no nothing. Looks #^@! good, too
Bruce (90RS305)
Old Jan 26, 2004 | 01:25 AM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
i tryed a drop down but the dis..cap is in the way
what about some custom kinda ram air looking think that would run from the top and i could lay it in that big blank space in the middle how would that work for a carb?
Old Mar 11, 2004 | 09:24 PM
Engine: L69
Transmission: A4
Well I FINALLY got a few pictures of the air cleaner, here it is:
Old Mar 11, 2004 | 09:28 PM
Engine: L69
Transmission: A4
CRAP! If anyone can tell me how to put a picture on here I'll get it up. Cant I just take a picture from my computer and put it on this site? Thanks
Old Mar 11, 2004 | 09:45 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is really easy. Right before you post click on the tab that says browse and it will open a window that will allow you to pick a picture or file from your computer.
Old Mar 11, 2004 | 09:51 PM
Engine: L69
Transmission: A4
Ok, I think I got it working now. Just disregard the very, very dirty engine bay
Old Mar 11, 2004 | 10:04 PM
Engine: L69
Transmission: A4
Number 2. Sorry if the pictures are fuzzy; im new to all this picture stuff
Old Mar 12, 2004 | 05:00 AM
90RS305's Avatar
Looks nice man, and a steam-cleaning may be in order to compliment it
Bruce (90RS305)
Old Mar 12, 2004 | 01:14 PM
Ronny's Avatar
i went with the oval elite edel 14 inch x 7 inch. clears the throttle shaft nicely injector pod is 2.75 inch and AC is 3.00 inch. have not yet installed. my adapter plate came with shaft to add the apparatus to hold down lid. the bend in shaft aligns the AC. to redo all you need is threaded shaft from hardware store. may be metric?
Old Mar 13, 2004 | 12:14 AM
Engine: L69
Transmission: A4
The only complaint I have about it is that I cant put a strut tower brace on it because the front of the triangle sticks out a few inches farther than a circle one. But owell
Also, where have yall put your IAT sensor?
Old Mar 14, 2004 | 10:21 PM
Engine: L69
Transmission: A4
Old Mar 16, 2004 | 01:06 PM
Ronny's Avatar
i found out the thread to the 454 TB is metric and the adapter on edelbrock is english. the howell adapter came with correct angled shaft just needs a trim of about 3/16 on each end. i dont use sensor.
Old Mar 16, 2004 | 01:27 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
Does it have to be a certain open air fitler for the LO3? Like diameter and model #?
Old Mar 16, 2004 | 01:31 PM
Ronny's Avatar
5 and 1/8 inch air horn. basic stuff. fits carb or TBI. Edelbrock Elite/ Summit. 14 x 7. cleared my linkage. dont know if it will clear the dist?
Old Mar 16, 2004 | 10:42 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I found some wires running back by the fire wall, i used electrical tape to secure it to those. Some people have drilled holes in the bottems of their filters and wired it up like that. but im too lazy .
-chuck
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
