One of Our Members, AndyZ28, Has Made Chevy High Performance
Old Jan 7, 2006 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the March 2006 issue, p. 24+. Andy was one of the first to mod for 1LE brakes (I believe Spohn sells Andy's conversion CD or used to at least)--and, of course, Andy's door-hinge kit has been around for a while (http://www.andyz28.com/). He was also the "head" behind my belt to dual electric fan conversion:
https://www.thirdgen.org/techbb2/sho...hreadid=309711
Congrats, Andy
Old Jan 11, 2006 | 04:08 AM
ebmiller88's Avatar
I saw that also, thought it was pretty neat. Andy was a big help to me in getting started in my brakes also, the 1LE upgrade on my Iroc was my first brake mod and look where I've gone from there.
Congrats to you, Andy. Looks like those hinges do the trick. Come paint time, I'm installing a set.
Ed
Old Jan 12, 2006 | 05:29 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
congrats on making the mag. I was wondering if anyone has done this besides andy. i want to atempt this but dont want to get in over my head. the article is a huge help but it always seems easy in a magazine. any more info will be good thanks.
Old Jan 12, 2006 | 05:51 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Props to ya Andy!
Old Jan 12, 2006 | 07:33 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Wadebryant
Car: 96 Z28, 91 RS, 87 IROC, 75 Corvette Stingray
Engine: 355, 5.7 TPI, 5.0 TBI, 5.7 LT1
Transmission: 400 turbo, 700r4's, 4l60e
Sorry for jumping in here so late but, I just went through the process of installing the upper hinge repair kit (I bought the greaseable kit) that Lon sells and at the same time also replaced the lower body side door hinges on both doors. The upper hinge repair kits and the new lower body side hinges made all the difference in the world! No more play or scuffed door jam paint.
The job start to finish, both doors, took me about 6 hours. The second door went faster than the first of course. The hardest part was getting the new bushing into the hinge without compressing it. The tip here is to slightly enlarge the hinge hole with a drimmel bit or carbide tip cutter just enough to allow the new brass bushing to be pressed into the hinge with your fingers. (I tapped the first one in and spent an hour polishing the new bushing so that the new pin would fit.)
Follow the instructions that come with the kit and have someone help you with the door. I used a engine hoist and sling to hold the door but the other set of hands will help guide it and adjust it when that time comes.
Taken from this post; https://www.thirdgen.org/techbb2/sho...ighlight=hinge
Old Jan 12, 2006 | 10:40 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
WOw wow wow, so is the kit i bought through classic industries the one you came up with? If it is and it looks like it i wanna thank you for saving my gfx from even more abuse than it took before the kit, adn now one gentle push closes the door
Old Jan 13, 2006 | 02:23 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Yes, the Classic door hinge repair kit, is the one they get from me. I am very glad you are happy with it.
Old Jan 13, 2006 | 08:47 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
congrats! i could use some new hinges...and weatherstripping...transmission...a house...
Brandon
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
Linson
Aug 21, 2015 02:12 PM
