v6 5 speed with a v8???
Old Dec 13, 2002 | 12:17 AM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
Can u use the 5 speed with a 3.1 in a 92 RS with a 5.0?? I am going to convert my six to an 8.
Old Dec 13, 2002 | 12:24 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
It's been done before.
Keep in mind that the V6 uses a smaller clutch disc and a 4:1 1st gear ratio which is a tad low for a V8.
Oh yeah, you'll also need a V8 bellhousing, fork, and clutch/slave cylinder assembly.
Old Dec 13, 2002 | 06:43 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
summit actually sells a clutch for the swap
look for a clutch for a 2.8 to SBC swap for a chevy S10 with a T5
summit sells it
you can also ordered one from McLeod, like i did
14spline X 1 1/8" hub on a 10.4 disc is what you'll need to order
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
RedLeader289
Sep 23, 2015 06:50 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
