View Poll Results: drag radials Nitto VS BFG
BFG DRAG RADIALS
36.36%
NITTO DRAG RADIALS
63.64%
Voters: 11. You may not vote on this poll
drag radial poll Nitto VS BFG
Old Aug 20, 2002 | 10:13 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
what do you guys think
what does your track times say
Old Aug 20, 2002 | 10:20 PM
JR305's Avatar
I have been thinking about picking up some drag radials to. So I will be watching his thread. All the research I have points to the BFGs being the better tire. You can check out the customer reviews at tirerack.com
Old Aug 20, 2002 | 11:03 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Ive heard the BFGs hook better but are rated to last 1500miles and the Nittos last 15000miles or something like that. I say get the Nittos because they are a better bang for the buck.
Old Aug 21, 2002 | 05:08 AM
Z_Ghost's Avatar
See sig, that was on the Nittos
Old Aug 24, 2002 | 10:01 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
my research says BFGs get better 60foot but wear more
you don't even want to think about BFGs if it will ever see rain.
Nittos are good for me.
Old Aug 24, 2002 | 12:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have about 6,000 miles on my BFG's and they look great still. i have also drove in teh rain with them and no problems eather....
Old Aug 24, 2002 | 09:35 PM
Gta-Paladin's Avatar
BFg's are BARE MINIMUM DOT. They're not really a radial lets face it.... Go with the MT Et Streets if you're thinking about it
The nitto is a radial. Bottom line
Old Aug 24, 2002 | 10:52 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The BFG's are a radial, no question about their construction. I have put about 6000 on mine so far and they still look OK. They are not a good idea for highway drives (mine get hot at 30psi on an extended highway drive)
Since you are talking 60ft times and still being streetable they will fill the bill. In chevy high performance this month they did tests between the different tires and next to a full blown slick, they have very respectable times. They found the best pressure is 11-12 PSI, any lower and they shake at the top end. Of course on the street 28-30 pounds will definatly add life. They stick like glue in the corners IMO unlike bias ply tires. I can't compare the Nitto Drag radial to the BFG's, I'm sure they both will work well. They both have a treadwear rating of 000 which doesn't inspire long life but what the hell
Old Aug 25, 2002 | 01:00 AM
jerflash's Avatar
the nittos actually have a rating of 100 not 000
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
fasteddi
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
