Cracked body near steering sector help!!!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I assume the crack can be welded, then stick in a Wonderbar, which is essentially a steering box brace.
JamesC
JamesC
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
In addition to the wonder bar you shold install the frame rail - to - cross member braces that were installed in the Z-28's and IROCS. I think these things were also installed onmost firebirds after 86.
There is one brace mounted on each side of the engine bay and they help keep the frame "square"....... early 80's Sports Coupes and Berlinettas didn't get these braces and the result is a lot of torn radiator supports on the drivers side frame rail ! ( due to the stress from the steering box ! )
There is also another addition brace that is mounted under the drivers side "battery box" that you could install to stiffen the front end up a little bit !
Car: 2000 astro
Engine: 4.3
Transmission: A4
hey john... do you have some photos of these braces? i'm working on a sport coupe, and want to make sure it's braced properly.
No Problem Robert,.......
I used to have pictures of these things while they were installed - but all I can find right now is this crappy picture I took a long time ago !!
