Anyone with Camaro GFX on their 'Bird?
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm thinking my stock GFX are a little boring. And I was wondering if anyone's changed their GFX to the '90-'92 style Camaro GFX? Would it be almost a direct bolt on? Pics would be nice too.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Rockers bolted on, door pieces needed 3 new holes drilled and the old 3 holes filled.
There are also 3 holes on each side where the brackets for the rockers attached that need to be filled as well.
I am not using any brackets on the rockers to attach to the fender and rear quarter panel at the moment since I am not good at body work.
Originally posted by Nate86
I like the "flame decal" on your hood and the phrase lick my ballz on your headlight.
Thanks.
This is what I did.
Removed the stock rockers, removed the small bracket that was attached to the rail where the stock rocker bolted to.
put the camaro rocker on.
Pulled off of the door piece.
test fitted the camaro door piece.
drilled 3 holes in each door, mounted door piece.
Friend came over and filled in the 3 original holes in each door.
And that is about it.
Just need to fill in the 3 other holes on each side of the body.
This is what I did.
Navy8125
Aug 22, 2015 07:13 PM
