cold start switch ?
Old Dec 20, 2002 | 06:56 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
cold start switch ?
what is a cold start switch and where is it at on the engine and does a 2.8L MPFI have this ??
Old Dec 22, 2002 | 08:35 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: cold start switch ?
I can only tell you what it is on my '87 L98.
It is a switch that monitors coolant temp at startup. If the switch sees that coolant is less than 100* (F) it sprays a 5 second mist of fuel from the cold start injector into the intake manifold to aid in starting when cold.
On the TPI manifold it is located under the throttlebody on the front of the manifold a little towards the passenger side. It has the identical kind of lock clip on it that a fuel injector does.
Old Dec 23, 2002 | 12:55 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
good to know/learn, thanks!
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
