cold start injector
Old Sep 2, 2005 | 09:10 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
cold start injector
i need some help guys. i need to replace my cold start injector in my 86 t/a. i thought it would be the same as the other injectors but it's not. i've tried to find it at the part stores around here, but i haven't had any luck. no store seems to sell it. i need to get it quick. where can i find one?
Old Sep 2, 2005 | 10:50 PM
Kwiksilverz28's Avatar
Just get an 89 TPI prom and eliminate the cold start system.
Old Sep 2, 2005 | 11:25 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I think changing the calibration to allow you to eleminate the cold start injector is the better option in the long run,
but you can find them on the web, and possibly autozone type stores.
http://www.autojunkiesclub.com/items/7984263788.html
Old Sep 3, 2005 | 03:02 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
U would have to modify the prom from 89 for your car since it has a VATS setup and you do not. No big deal and any capable tuner could do it easily.
It is simpler and a lot less prone to problems if you do go this route and disable the cold start inj completely.
If any of this scares you, I would recommend replacing the cold start inj. and the switch that controls is and be on your way
later
Jeremy
Old Sep 3, 2005 | 06:40 AM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
i appreciate the help guys. i'd love to eliminate the cold start injector all together, but i don't really know how to tune a prom. and i;ve allready spent $130 dollars on a stage 2 performance chip for the computer allready in my car.
for now i'm just gonna replace the injector. later down the line when i know more about programming i will eliminate it all together.
thanks for the help guys.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
