compression test results
Old Dec 24, 2003 | 10:34 PM
llvll4l2c91350's Avatar
how does this look. engine is a 350 TPI in an 89 Formula with 156K miles.
8. 160 7. 167
6. 160 5. 167
4. 165 3. 170
2. 165 1. 165
Old Dec 24, 2003 | 10:40 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
looks good!
Old Dec 26, 2003 | 09:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
No problems.
Old Dec 26, 2003 | 08:53 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
as long as the number from all cynlinders are in the same ballpark, probably mosty likely could very well be no if ans buts about it = good..
Old Dec 27, 2003 | 06:38 PM
ede's Avatar
ede
looks like you're half done
Old Dec 27, 2003 | 07:02 PM
i think im leaning towards rebuilding this engine. since the compression is good, is it likely i wont need to bore it and get new pistons and rings? maybe just refreshen it with new bearings and gaskets? i know i need to take the motor apart to find out for sure but not ever having done this before its hard for me to know what to look for. i just want a fresh bottom end that will go for several thousand miles more. with what i'll learn from doing this, i will know a lil better what to look for when the time comes to disassemble the 91 motor with the knock.
Old Dec 27, 2003 | 09:59 PM
Vader's Avatar
You could have a bore worn as much as .005-.007" oversized (or even more on the bottom end of stroke) and still be sealing well. Only measurement of the bore will reveal the wear, taper, and roundness of the bores. However, at least there is apparently no significant failure of the rings, lands, valve sealing, and cylinder walls. You may still need replacement pistons and boring, but you may not either. As a general rule, I think it's always a good idea to at least break the glaze of the bors and install new rings, even it they are stock bore.
Old Dec 28, 2003 | 07:07 AM
ede's Avatar
ede
the engine i'm working on now was the cleanest best looking engine i've ever taken apart. the pistons still looked new, it had .008 taper/out of round and needed bored. you just never know untill you get inside and look and take soem measurements. the 4.3 i rebuilt in my truck a few years ago was the nastiest engien i ever had apart. black sludge every where. piston had a flame cut notch in down it and after 95,000 miles the bore was good and i didn't have to have it bored, just a new set of pistons.
Old Dec 28, 2003 | 06:12 PM
ok so basically the first step would be to have the block thoroughly checked once i have all the parts out of it. also im gonna talk about this rebuild with the machine shop that did my heads. thanks for the help.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
