CTS Test Values
Old Apr 14, 2004 | 01:53 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
CTS Test Values
Anybody got a table or something that tells what resistances the CTS should have at certian temperatures? I am trying to narrow down a problem with my engine apparently overheating (according to WinALDL datalogs) and I am starting to think bad CTS. Any help would be great!
TIA!
Old Apr 14, 2004 | 10:15 PM
steve8586iroc's Avatar
If you have a spare cts you could put it in a pan of water and heat it on your stove top. Watch the resistance change as the temp goes up. Use a good baking thermometer to keep track of the water temp as your checking the sensor with your meter.
Steve
Old Apr 15, 2004 | 07:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Heres one... You can test it by using ice water (0 deg C) and boiling water (~100 deg C, depending on what your altitude is). Use a dvm to measure the resistance and compare.
Old Apr 15, 2004 | 07:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Wow that is some excellent data to have. Anyone should be able to test theirs now. It is always nice to test sensors before you go out and start replacing them.
Old Apr 15, 2004 | 08:52 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Dimented, that was EXACTLY what I was looking for. I even called the f'n stealership today and THEY didn't have that.
You da MAN!!! Beers to ya!!!
Old Apr 15, 2004 | 09:50 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I forget who origionally posted that table but kudos to them. Really helps to see what the expected resistances should be.
Old Apr 15, 2004 | 10:28 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
YES it does! Thank you!
PurelyPMD
May 5, 2016 04:57 PM
okfoz
Sep 22, 2015 03:37 PM
BWilcox
Sep 20, 2015 12:19 PM
Blkdth87
Sep 16, 2015 01:40 PM
ULTM8Z
DIY PROM
Sep 16, 2015 09:15 AM
