Cross drilled-slotted rotors, are they worth it?
Old Mar 27, 2002 | 06:15 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have a 87 GTA and a 89 IROC-Z and i have the opertunity to buy some raybestous brute stop slotted and cross drilled rotors for about 60 dollars a piece since I manage a parts store. Are these worth it or should I keep the stock ones?
Old Mar 27, 2002 | 08:03 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
They'll look good. There isn't much of a performance gain with them. Save you stock ones for when they do need to be replcaced.
Old Mar 27, 2002 | 10:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is it true that slotted (or cross drilled) rotors can't be turned? I heard that somewhere. JC Whitney sells some slotted front rotors for $60 or so, I was thinking of getting 'em if my rotors become that thin. I'm sure they're not Raybestos, though!
Old Mar 27, 2002 | 10:16 PM
turningfast's Avatar
They cross drill them to expell heat to reduce brake fade, and slot them to help get rid of the gasses that form between the pads and disks from heat (kindof like hydroplaning and aquatread, sort of)
Old Mar 28, 2002 | 02:23 AM
j166a99's Avatar
im not sure if cross-drilled rotors can be resurfaced, but i am one that can vouche that they do indeed add a noticeable performance in braking.
incase you're wondering i ordered a set from powerstop...
Old Mar 28, 2002 | 09:12 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Didn't notice any improvment when running thought the canyon with them. They just look good.
Old Mar 28, 2002 | 02:27 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
from what i've heard there's no point in slotted rotors any more because modern pads don't produce the gases they used to.
Old Mar 28, 2002 | 07:57 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Slotted and crossdrilled rotors are now mainly for appearance. Year ago when brake pads were made with certain gases, the slots would allow for the gases to escape and thus increasing the braking performance. Today's brake pads are better and most don't even cause those gases anymore. So if you're looking to stop quicker with slotted and crossdrilled rotors, save your money for the 1LE upgrade or Baer or something to make your car faster.
Old Mar 28, 2002 | 08:12 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
This subject has already pretty much been discussed.
Here is the link to an old post:
https://www.thirdgen.org/techbb2/sho...threadid=59646
Old Mar 29, 2002 | 04:51 PM
GreenProStreet's Avatar
What he said, but...
Slotted and cross drilled rotors free up a lot of excess rotating mass, as well as decrease the unsprung weight. The combination makes the acceleration, breaking and suspension response more crisp.
Old Mar 29, 2002 | 05:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for that link, Andy! I think I've changed my mind, maybe when my rotors thin out, I'll stick to buying regular rotors instead of the JC Whitney slotted ones.
Old Mar 29, 2002 | 05:25 PM
Shaun 90 Iroc's Avatar
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
I have the PowerStop Cross drilled rotors.. i noticed a definite decrese in braking ditance. I love them. They do make a difference over the stock ones i had. Pads make a huge difference too.
Old Apr 1, 2002 | 02:14 PM
MikeDwhoROCZImports's Avatar
I talked to Baer and they recommended against crossdrilled rotors for high heat racing applications because they are more prone to cracking.....
Old Apr 5, 2002 | 12:26 AM
Kandied91z's Avatar
no point going into them, i have the gm versions an love them. here's a pic when i was working on everything.
anyone know if you can purchase a better caliper that will fit on the stock setup?
Attached Thumbnails Cross drilled-slotted rotors, are they worth it?-close-up-suspension-1.jpg
PurelyPMD
May 5, 2016 04:57 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
the_hamturdler
Sep 22, 2015 02:59 AM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
