How to check TBI fuel pressure?
Old Mar 10, 2003 | 01:25 PM
Tmony69's Avatar
Car: 89 IROC x2
What is the best way to check fuel pressure on a TBI? Does anyone have a drawing of a home made gizmo or something?
Old Mar 10, 2003 | 02:08 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I dont know any other way than getting a fuel pressure gague. I got the Summit 0-30 psi with their little t fitting ($5) and then cut the rubber line and clamped it down hard. I was worried that the 16 psi system would blow the fitting off, but I didnt have any problems. Its kind of a ghetto way of doing it, but I didnt want to cut the hard lines and couldnt afford braided lines at the time.
Old Mar 10, 2003 | 10:05 PM
Tmony69's Avatar
Car: 89 IROC x2
Makes sense, almost to simple. I had this complicated adapter vision in my head, but only 16 psi is not that big of a deal. Thanks. Anyone else have any ideas?
Old Mar 11, 2003 | 08:49 AM
Vader's Avatar
I made an adapter from the end fittings of an old fuel filter, a copper refirigeration 'T' and refrigeration Schrader valve, allong with a little tube swaging and silver solder. It was sized and spaced to replace the filter, which is a PITA on a ThirdGen.
Old Mar 11, 2003 | 01:24 PM
Tmony69's Avatar
Car: 89 IROC x2
Thanks Vader, I'll try it.
Old Mar 12, 2003 | 03:24 AM
JPrevost's Avatar
Car: 91 Red Sled
Vader, what are the fuel filter threads? I want to move the filter up to the front to the flex lines or replace it all together with a clear homemade filer housing using reusable elements.
For $30 you can have yourself a t-fitting for the flex lines and a 1.5" 0-30psi liquid filled gauge that'll give you good readings when compensated for it's sensativity to temp. On a cool nite, hold the housing and watch the pressure reading change.
Old Mar 19, 2003 | 04:57 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Which hose do you cut into?? I see two lines and does this gauge reflect the changes you make with your regulator on the TBI unit???
Old Mar 20, 2003 | 01:06 PM
Tmony69's Avatar
Car: 89 IROC x2
You cut the hose that goes to the bigger metal line. It is usually the top one. The inlet side of the TBI is on the drivers side. In my case I remembered that I had a VDO inline pressure gauge in my truck. It read from 0-30. I cut the hose and installed it, then used a double ended barbed fitting, and some hose clamps to put it back together. As it turn out, I did have a pressure problem, and was only getting 5psi. But this was after assuming the pressure was fine, and I spent days chasing down other stuff. The damper on the fuel pump was leaking and letting all the pressure back into the tank. Good luck.
Tmony69's Avatar
Car: 89 IROC x2
And yes it will reflect changes made at the regulator.
Old Mar 20, 2003 | 05:02 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Thanks, Tmony will try as soon as my stuff gets here from Summit.
Old Mar 20, 2003 | 11:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
brians (z28 boy) has a bad *** setup, might want to check it out
Old Mar 23, 2003 | 09:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
16 psi aint crap, coolant system gets to 15 psi and all you need is hose clamps for that...
Old Mar 24, 2003 | 09:28 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Here's my Summit 15psi liquid filled fuel gauge.
Old Mar 24, 2003 | 07:19 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Ok I installed my pressure guage and I am running at 12.5 psi is that right for my motor and really no major mods as you see below.
Old Mar 24, 2003 | 07:24 PM
Tmony69's Avatar
Car: 89 IROC x2
Yes that is perfect. It's at the upper end , but good.
Old Apr 11, 2003 | 08:06 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
anyone know if theres supposed to be a difference between the pressure at open loop and the pressure at closed loop?
Old Apr 11, 2003 | 11:02 PM
Tmony69's Avatar
Car: 89 IROC x2
If you are talking about fuel pressure, there shouldn't be. I know on the TPI cars there is a drop at idle that is controlled byt the regulator, but I couldn't say for sure about TBI cars. I was the guy that started this thread, and once I got my problem solved, the fuel pressure stayed at a constant 11-12 psi.
Old Apr 18, 2003 | 10:19 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Axle/Gears: 10-bolt w/3.73s
here is mine...i have made a lot of changes since this pic was taken (a year or so ago) but it is still basically the same.
i know this is probably a little more than you were looking for, but it may give you some ideas.
i have a whole page or two dedicated to TBI fuel lines etc. on my site (in my sig) if you need any info.
-brian
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
