Electronic speedo swap, 110 to 145, what do I need???
Old Sep 24, 2003 | 05:05 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I got the whole 145 gauge cluster and swapped it in, but the speedo didn't read correctly. It read 15 mph when I was really doing 35 or 40.
Do I need to change any of the speedo gears or anything like that?
I currently have 3.08 gears but will soon be switching to a 4th gen rear with 3.42's so if I need to swap any speedo gears I'd like to do it all at once.
Thanks.
Old Sep 25, 2003 | 05:48 PM
Merlin's Avatar
IIRC, your '89 and '90 should both have an electic speedometer. If that's the case, you need whatever gearing will send the speedo head 4,000 pulses per mile from the VSS.
I might be wrong, though. Camaros may have changed from cable to electric in '90.
Old Sep 25, 2003 | 06:35 PM
Merlin's Avatar
BTW - A '730 ECM should get 4,000 PPM. I believe you should have a '730 ECM in both those cars.
Old Sep 25, 2003 | 06:42 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
The '90 speedo is electronic. How do I know what gearing would send 4000 pulses?
Old Sep 27, 2003 | 10:09 AM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
ttt, still looking for help on this
Old Sep 28, 2003 | 11:00 AM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Any more help on this, I'm still confused about what to do?
Old Sep 29, 2003 | 03:15 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
scan through this page, it might save you alot of hell and thinking and trying wrong parts and gears when all you need to do is exactly what this box can do. Simply recalibrate your speedometer a bit. Check out the pdf instructions in there.
http://www.dakotadigital.com/
Old Oct 1, 2003 | 05:05 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Thanks, I appreciate the suggestion. I'd prefer to fix this problem without spending $80 though so I'll save this as a backup idea right now.
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
beastin91rs
Oct 9, 2015 07:38 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
