How to make your own asjustable aluminum LCAs inside
Old Jul 19, 2003 | 12:51 AM
89ProchargedROC's Avatar
step by step
http://www.jonaadland.com/Z28/Mods/L...minumLCAs.html
i bet a monkey could do it
Old Jul 19, 2003 | 02:37 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Haha i tried that before I bought my BMR arms and phr. I just couldnt find the spacers / reducers needed to fit it, i was trying to find them stepped like the pre made ones include.
Now i have two junk aluminum tubes, and 4 spare rod ends for my bmr's. Dont matter though initially i ordered the wrong length tubes.
Old Jul 19, 2003 | 05:24 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
On that same site he also has a diy panhard bar
Old Jul 21, 2003 | 06:07 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Nice stuff, a real good website.
Old Aug 2, 2003 | 10:30 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
That is a great website. That's what I call smart engineering.
Tom
Old Aug 3, 2003 | 07:20 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
I could just be an idiot, but wouldnt aluminum be lousy for chassis support? I know steel is heavy and all, and as far as the stock pieces go, balsa wood is better, but aluminum seemt too soft for chassis reinforcement.
Old Aug 3, 2003 | 09:13 AM
AFatHippo's Avatar
Car: '88 Camaro
yeah, i wouldnt ever use aluminum for my control arms. they may be stronger pound for pound, but steel is just plain stronger, period.
Old Aug 3, 2003 | 04:55 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
The load on the LCA's and PHR never varies more than 20* from being linear. If it was something that had a lot of side-loading it would be an issue, but they should be plenty strong for street use (unless your local roads are more like spaces between potholes.)
Old Aug 4, 2003 | 12:41 AM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Guys,
Those control arms are more than strong enough for the application. Keep in mind the size of the tubing...1.125" Keep in mind it is a chassis race shop that sells the aluminum tubing... http://www.colemanracing.com/section/index.htp?id=638
Here is a quote from the following website;
http://www.luminum.com/
" 6061 This heat treatable alloy provides very good corrosion resistance. It takes finishing very well. Easily welded, 6061 is about as strong as mild steel, making it a widely used general purpose alloy. It is easy to machine and, when annealed, it is very workable, retaining its qualities if it is heat treated without aging. End uses of this alloy include aircraft landing mats, marine vessels, structural and architectural components, storage tanks, highway signs and many components in transportation equipment. "
This is from another website...
http://www.bostoncenterless.com/properties/resulta.cfm
"Applications
Commonly used in the manufacture of heavy-duty structures requiring good corrosion resistance, truck and marine components, railroad cars, furniture, tank fittings, general structural and high pressure applications, wire products, and in pipelines."
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
z28addict8490
Aug 7, 2015 08:48 PM
Poncho92
Aug 7, 2015 08:15 PM
