Running fuel from the return line instead of the main line.
Old Apr 22, 2003 | 03:30 PM
Duke901's Avatar
Car: 89 Formula
I posted before about switching from tpi to carb. Im wondering if i can put in a regular pump on the block and then run the line to the return line to get fuel from the tank. Would this work?
THANK YOU
Old Apr 22, 2003 | 05:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You want to suck fuel from the tank via the original return line? If that's what you're asking, it won't work. The return line just dumps fuel back to the tank. The feed line is what has the pickup and the in-tank filter on it.
You'd have to really overfill the tank to make any use of the return line!
Old Apr 22, 2003 | 06:20 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you have two options, use the electric pump and put a regulator on it and adjust it down or unplug the electric pump and simply hook the feed line up to a mech pump and suck fuel right through the old pump using it at simply a pickup and not a pump.. both methods work.. i am using my electric pump.. others have used mech.. some people have switched to mech when the fuel pump burns out because its easier then droppin the tank..
Old Apr 22, 2003 | 08:06 PM
Duke901's Avatar
Car: 89 Formula
So if i run it through the pump in the tank it wont mess up anything. Also to put a mechancal pump on the fuel injected block, i just have to get the pump rod and the fuel pump.
Old Apr 22, 2003 | 09:13 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Hold on ...you may not be able to pull through the old pump...I couldn"t...some can....some cant..one of those mysteries.....your choices may be a regulator or pulling the electric pump and dropping in a hose to syphon.....
Old Apr 22, 2003 | 10:44 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I went from TBI to carb and I just ran my stock pump with a regulator. The new 350 I put in my car doesnt even have a place on the block for a mechanical pump so I dont have that option anyways.
Old Apr 22, 2003 | 11:01 PM
pskel350's Avatar
Re: Running fuel from the return line instead of the main line.
THANK YOU
thats what i am doing, and it works perfect. when i first did my engine swap i tried to pull fuel through the in-tank pump, but my carb ran out of fuel at about 4900 rpm's...makes for real slow 1/4 mile times
on my gas tank the pick up fuel line and the return fuel line are exactly the same height in the tank
Old Apr 22, 2003 | 11:44 PM
Duke901's Avatar
Car: 89 Formula
So i should try the return line and if that dont work then try pulling through the old pump. If that fail's then use the in tank pump and just rewire it to come on.
Old Apr 23, 2003 | 05:42 AM
Engine: 406
if you use the intank pump you will need a regulator...I use the malory 3 port.. www.summitracing.com
part#MAA-4309..easiest of all sollutions.
Old Apr 23, 2003 | 05:44 AM
Engine: 406
you want to run 5-7lbs of pressure..
Old Apr 23, 2003 | 07:56 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
dear duke.
YES YOU CAN, also you'll notice that if you disconnect the return line it leaks inmediatelly and it will continue to do so untill your gas tank is totally empty.
i've been there, done that, just added a in-line filter, and new lines away from heat of course, and drove without any problems untill decided to use the electric pump with a pressure regulator, because my new block doesnt have mechanical fuel pump provision.
the mechanical pump WILL NOT suck fuel thru the electric pump, i've tried and belive me, your engine will die every 5 minutes.
the best to do, is (in my humble opinion) to use the return line until you get money for the pressure regulator, the guys at edelbrock told me never to exeed 6psi. on my 1406, but it seems that you can "push it" a little bit to 7.
now is up to you.
Fernando.
Old Apr 23, 2003 | 10:07 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
what about using 2 pumps?....the stock tpi intank one and another elctric one, then a regulator?...
Old Apr 23, 2003 | 11:34 AM
Duke901's Avatar
Car: 89 Formula
Ok, i will run it through the return line. I was just worried that if the tank got to low it wouldnt be able to get fuel from the bottom of the tank, or when i turn corners to hard it would die.
THANKS FOR ALL THE HELP EVERYONE.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
