Carpet install, is it brutal?
Old Feb 6, 2005 | 03:02 PM
pyrokilla's Avatar
Car: 88 formula
Engine: 305 tpi
Transmission: M5
Ok, so my **** *** red interior is on its way out, is installing carpet a bitch? any tips?
Old Feb 6, 2005 | 03:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sure remove all seats and center console. remove some interior and install....probably 4 hours work if you're slow about it.
Old Feb 6, 2005 | 05:14 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
take your time cutting out(enlarging) the hole for the shifter/console....one tip I saw that came in handy was to make sure your carpet was slid all the way forward...into position,before you start marking /cutting
all in all,its not a bad job,and VERY rewarding
Good Luck
Steve
Old Feb 6, 2005 | 11:11 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Yep, not too bad at all, but like Brock said, make sure your carpet is slid all the way forward! I didn't check myself as much as I should have and I now wish I'd had mine an inch or two father forward, but overall it still looks so awesome compared to what was in there before that it doesn't bother me too awefully much. Just take your time and you'll be happy with the results!
-Paul
P.S. please excuse my nasty floor mats...I need to get new ones!!
Attached Thumbnails Carpet install, is it brutal?-c-misc-pics-ta
Old Feb 7, 2005 | 12:15 AM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
make it easy on your self and save the money for a pre-fit pre-cut carpet for your car. That way there is no errors, or odd corners you have to cut and mend around. Avaliable throught www.yearone.com and I think still avaliable through www.jcwhitney.com
Old Feb 7, 2005 | 12:59 AM
82knightrider's Avatar
Transmission: TH200C....700R4
-Paul
looks very good ,now just get some floor mats..lol..IMO..though
Old Feb 7, 2005 | 02:17 AM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
Also avalible on Ebay from A1 AutoParts I think is his name, precut, molded and such. Thats who i was looking to buy mine from.
Old Feb 7, 2005 | 04:15 AM
Car: 87 IROC
I got mine from 1A auto Also..it was an ACC carpet
Dont let anyone fool you,no matter how much they say its "molded" ,trust me you still need to trim/cut
yearone sells ACC carpets,same as 1A auto,probably JC whitney as well,along with the board sponsors up top
Steve
Old Feb 8, 2005 | 01:07 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I was at a upholestry place last week looking at having my seats redone two tone(black and grey) and the guy there said to make sure i get acc carpet when i do mine, said it was the best quality reproduction carpet you can get.....this guys been in business for 30 years, i've seen his work he knows his stuff. My dad got his 81 carpet from classic, its acc and teh fit and quality is unbelievable.
Old Feb 8, 2005 | 07:44 PM
coolcamaroZ28's Avatar
Car: 95Z / 91Z / 10SS
Engine: LT1 / LB9 / LS3
Transmission: T56 / 700R4 / TR6060
I just re-did mine and must say that it is definately worth the time. Check out my website for the step-by-step transformation...
http://www.coolcamaro.cz28.com/photo3.html
I got both the seats and the carpet from ABC upholstery. They get their stuff from the same distributor as the big boys, with a discounted price...
http://www.abcautocarpetandupholstery.com/
Old Feb 8, 2005 | 11:57 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Hate to bring it to you
8285*ACC 1985-1992 Carpet Complete with Console & Cut-Outs $197.50
is without shipping, A1 Auto off ebay is less then $200 US shipped to my door in Canada, cheaper in the states.
Old Feb 9, 2005 | 01:32 AM
Car: 91 Camaro RS
Engine: TBI
Hey whats the deal with acc carpets in classic ind tehy say 89-92 hatch area has to be altered to fit, i know those years its a hair smaller back there but havent called to find out, what kinda alterations tehy talking?
Old Feb 9, 2005 | 03:56 AM
Graboid's Avatar
www.carmotorsports.com
excellent quality
Old Feb 9, 2005 | 01:09 PM
Faded's Avatar
Car: '91 Firebird
excellent quality
Agreed. I bought a full carpet set from them. Haven't been able to install it yet. Too cold.
Old Feb 10, 2005 | 08:57 AM
Cali Z's Avatar
I purchased an 830-buckskin pre-molded carpet for 115 plus shipping. The brand was Trim parts inc. from www.stockinteriors.com.
Installation went in nicely, needed to be trimmed up like any pre molded carpet, but good price.
Old Jun 22, 2005 | 10:36 PM
john1221's Avatar
Car: 89 IROC Convertible
When you installed your carpet did you remove the seat belt anchors or not? It doesn't look like a torx bit will work, at least no the T45, T50 I have. If you didn't take out the belts than did you just make a single slit to slip the carpet over them?
Old Jun 22, 2005 | 10:40 PM
Car: 91 Camaro RS
Engine: TBI
The outer belts you dont have to unbolt the inners ie console and against the hump i took out and just slit a small hole for the bolt
Old Jun 22, 2005 | 10:59 PM
john1221's Avatar
And what tool did you use to get the bolts out?
Old Jun 22, 2005 | 11:20 PM
Car: 91 Camaro RS
Engine: TBI
it was a torx 50 lightly tapped into the head since the t-45 seemed to be wanting to slip used a long ratchet on em
Old Jun 23, 2005 | 09:18 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
that's because it's a T47. i stripped by T45 before i realized they even made a T47.
Old Jun 24, 2005 | 09:39 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
I too thought jcwhitney had pre-cut ones, but jcwhitney only has PRE-MOLDED ones. You still have to cut there carpet. Just becareful for the seatbelts, i did a little slit for mine and it turned out to be about a 3-4 inch slit once the seat belt was all the way through.
Old Jun 28, 2005 | 05:34 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I got a complete set from 1aauto...and must say I was impressed with the fit...The back section just fell into place, and little trim fitting on the front....
But to beat a dead horse make sure it is all the way forward, I used my take out as a template and everything went great....
Old Jul 3, 2005 | 08:57 PM
john1221's Avatar
Thanks for tip on using a T47. I bought a complete set with the T47 at Sears. (The Torx brand Master set)They do not have the T47 by itself. I posted before that my Dove Gray carpet that A1 Auto lists as #877 had a blue tint. Well it took them more than a week but they sent me the samples they promised. It confirmed that #877 is the correct matching color for my interior only the carpet they sent me is not the same color as the sample!. I'm not sure I am going to wait on a replacement.
I stripped the seat frames out today and sandblasted the rust off of them today. I decided to use a "rust fix" spray on the shifter and other parts so I did not have to take them out of the car.
Old Jul 3, 2005 | 09:04 PM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
I just put new carpet in my third gen im restoring. It took me 2 hours or so, What I did was layed my new carpet out then layed the old on top of it and formed it as close as i could as to what it is in the car then took fabric dye spray paint and marked the holes and it was pretty damn close and made the install really easy. Some people may not be up for dying parts of their new carpet though but it is all hidden once seats and center console are bolted back in.
oh also i let my carpet sit out in the sun for the afternoon to make it softer and easier to work with. All in all it probably took me 45-60 minutes.
Old Jul 3, 2005 | 09:37 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
This happend to me too. What did you do to fix this?
Old Jul 4, 2005 | 01:46 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
-Paul
hi, on ur seats those 4 buttons on the side in a circle. what do they do? cuz mine dont work i took my seats out for the first time and knoticed air tubes runing up the back somewhere....theres also a **** conected to the wireing connected to the box the airtubes are at. i got really confused when i found that out....i jsut wish i knew what it acutally is
Old Jul 5, 2005 | 12:46 PM
quadgoat's Avatar
Car: 1992 Firebird
Those buttons control the power inflatable lumbar support and side bolsters in my seats. The air pump is under the passenger seat and control wires along with pressure lines run under the carpet between the passenger and driver seats. I had to make my own wiring/air harness when I installed my seats, but everything works great now! Hope I helped!
-Paul
Old Jul 5, 2005 | 07:24 PM
-Paul
yeah now i know what they inflate. do u have any pics of what u made or a wireing diagram?
Old Jul 5, 2005 | 08:29 PM
quadgoat's Avatar
Car: 1992 Firebird
Unfortunately I don't have any wiring diagrams or pictures. All I did was match the wiring up color by color between the two seats and run vacuum line between the seats that was a good size to hook them together. It was pretty simple really. Then I just ran a single power wire to the fuse box. It's pretty straightforward, but I wish I did have more pics from my carpet install. Let me know if I can help out with anything else!!
-Paul
Old Jul 5, 2005 | 08:33 PM
-Paul
ok thanks for the help. i doubt ill get around ti fixing it anytime soon but i didnt think it would be too hard....and all the wireing and hoses are all there i just gotta figure out why its not werkin
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MORREALE5
Sep 13, 2015 09:16 PM
