NEW 350 knock sensor and ??? sensor.
Old Feb 11, 2003 | 09:15 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Well I just got my two sensors in the mail for my 350 TBI setup. Does anyone know what this sensor does? I am sorry for the blurry pictures, cheap camera. I am not even sure where the thing goes yet .
Old Feb 11, 2003 | 09:16 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Here is the other pic.
Old Feb 11, 2003 | 10:43 PM
r90camarors's Avatar
Engine: LO3;383tpi
I think it's the ECS module, but don't quote me. Your knock sensor will be a screw in deal
Old Feb 12, 2003 | 02:28 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Dude I just went to the part's store today and bought a new esc and knock sensor. the part that you have the pic of is the esc. it goes on the driver side up against the firewall. it is behind your fan and fuelpump relays not hard to change at all. but be carefull with the knock sensor. you will need a 21-23 mm socket to get it out, dont know witch one for sure If you need any more info on this just pm me and i will be glad to help.
Old Feb 12, 2003 | 06:12 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Thanks I appreciate that. Do any of you know what the ecs sensor does? Could you tell a difference on how the car acted at all? Thanks. I got both of these from GM parts direct and spent $71.59 on the parts.
Old Feb 12, 2003 | 06:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ESC module is an acoustic filter. It is not a sensor. It's job is to filter and analyze the audio stream from the knock sensor (which is a microphone).
If the ESC module detects what it considers knock it will then signal the ECM. The ECM responds by reducing the SA.
In my experience the ESC module is more important then the sensor. It is not a simple device.
RBob.
P.S. Torque spec for sensor is 11-14 ft/lbs. Don't over tighten it!
Old Feb 12, 2003 | 03:16 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Thank you it sounds like you have done your home work on this. I had no idea the knock sensor had a torque value. Thanks again.
Old Feb 20, 2003 | 07:41 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Hey guys
Yeah, its been a while, this summer was awesome thanks largely in part to the ole' camaro. My TBI setup has definitely come a long way, but i'm still getting one little glitch.
When i really pound on her she throws an ESC (electronic spark) code. Now, i never replaced the spark module when i swapped in my 350, though i did the knock sensor, so is it maybe reading my 350 like a 305 and thinking its running into detonation and thus throwing my timing back causing the car to feel like its hesitating? Whaddya guys have to say, you've never failed me before.
Ty
Here's the current setup...she's evolving...lol
1988 RS Camaro
TBI 355 (powdered rods, forged pistons, balanced, blueprinted, crane-compu cam, ported/polished heads)
WC T-5
3.73 Posi
Edlebrock Strut Tower Brace
Wonder Bar
Eibach Springs
KYB Struts
Accel ignition/coil
3-row radiator
180' thermostat
custom e-prom
ect. ect. ect.
Shiny bright orange paint w/white stripes soon...
Old Feb 21, 2003 | 03:34 AM
Car: 89 Camaro RS
Engine: 355 TBI
that will do it, you need to get the esc too, i bought one at autozone and it was about 50.00 buck's
Old Feb 21, 2003 | 10:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by TP355Z
...but i'm still getting one little glitch.
Sounds like the ESC forced knock test is failing. Do you ever get knock counts? Can you ever hear it knock?
RBob.
Old Feb 21, 2003 | 08:57 PM
iroczrockz's Avatar
Car: 91 RS Camaro
MAN I KNEW IT!!!! this is biting me in the @ss!!! I can't get the old 305 knock sensor off. Who in the world thought of making the thing out of aluminum? It just stripped all the way around. You guys have any ideas on how to get the dang thing off? I am pulling my hair out over this stupid thing. I put the ESC sensor in but, will the old knock sensor work with the 350?
Old Feb 22, 2003 | 07:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Pipe wrench.
RBob.
Old Feb 22, 2003 | 08:05 AM
Car: 89 Camaro RS
Engine: 355 TBI
Man i know what your talking about im haveing the same damm problam. I cant get the knock sensor out of my car either. And i dont think thier is enough room to fit a pipe wrench in thier but ill try
Old Feb 22, 2003 | 08:16 AM
iroczrockz's Avatar
Car: 91 RS Camaro
That is me too. No room. I am thinking I am going to have to take out the starter or something. This is so irritating.
Old Feb 22, 2003 | 04:41 PM
iroczrockz's Avatar
Car: 91 RS Camaro
I went out and bought a slip wrench from walmart. I hope this works.
Old Apr 16, 2008 | 04:26 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Re: NEW 350 knock sensor and ??? sensor.
Will the ECS make the car not want to run? Or idle properly?
Old Apr 17, 2008 | 07:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A bad ESC system can cause driveability issues. If there is a lot of false knock being reported the ECM will be retarding the timing.
At idle knock counts are ignored. However, this is at an idle RPM. If the idle RPM is a tad high then knock counts will cause spark retard.
Best bet is to use a scan tool and see what the Knock/PA3 counts are.
RBob.
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Eric-86sc
Aug 24, 2015 09:01 PM
gwade12
Aug 8, 2015 08:17 AM
