LED Guages
Old Apr 9, 2003 | 01:05 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
LED Guages
ok iv searched for this but havent found anything, what i want to do is light up my guages with LED's...the plates(fuel and speedo)are metal, i thought they were paper or something other than metal...what do i do and how do i do it? any advice is welcome.
Old Apr 9, 2003 | 01:22 PM
Nightcruzer's Avatar
Car: Trans Am
There is a "how to" right in the technical articles under beautification.
Old Apr 9, 2003 | 02:50 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Thats where I got mine. Looks good to.
Brian
Old Apr 9, 2003 | 03:29 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Anyone know what size bulb were supposed to get???
Old Apr 9, 2003 | 03:45 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
194s are in my GTA
Old Apr 9, 2003 | 04:47 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Forgive me for being ignorant- but will installing LED's in place of the factory bulbs give the gauges that bright white glow like a stock Caddy Deville or Infiniti I30?
Old Apr 9, 2003 | 08:30 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
not quite that bright man...
i wish i had a pic.. picture the infinity like 2 times less bright..and only in certain places...still looks 100000 times better then stock, but not to the point of the infinity...(you pay alot of $$$ for that)
ill have some pics up soon..
iroc2nv
Old Apr 9, 2003 | 08:36 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
how did he get blue ? there are no blue led's on that page ?
Old Apr 9, 2003 | 09:06 PM
GarageToys's Avatar
Yeah, I know... and I don't even get to drive it.
Old Apr 9, 2003 | 10:23 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
If you are refering to me and the page that I linked you might want to scroll down. If you count the items, it is number 19 from the top. The pic looks like this
Brian
Old Apr 10, 2003 | 08:10 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Brian
Brian,
Which ones did you use? The single or double LED 194's?
Thanks.
Has anyone tried these in a pre-'92 gauge cluster? How's it look?
I made my own blue 194's a while back using 10000mcd LED's, home-made PC boards and SMT resistors. Fun project but what a PITA.
Old Apr 10, 2003 | 12:15 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I used the single. If I could go back and do it over I would probably go with the double or even quad leds. It is plenty bright at night the way it is right now, but when it is dusk(or whatever you wanna call it) you cant show anyone cause it is to bright out side.
Brian
Old Apr 10, 2003 | 05:16 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
i haven't torn the dash apart yet, how many do you need, i am going with red
Old Apr 10, 2003 | 05:23 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
If I remember, 9. I bought 15 to be safe. I put the 9 in the dash, and 2 in the floor lights. I am going to buy their dome LED also.
Brian
Old Apr 10, 2003 | 06:30 PM
DreamState21x's Avatar
plug in
Are theses LED lights just a plug in replacment or is there more to it..? Thanks.... Looks nice by the way..
Old Apr 10, 2003 | 08:35 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Re: plug in
Just a straight replacement. Here are some pics.
Regular Blue 194s
194 Blue LEDs
Dash with blue 194s and Blue 194 LEDs
Old orange rubber lights, 194b's, and 194 leds
Hope this helps
Brian
Old Apr 10, 2003 | 10:04 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
Hey that looks awesome, I think i'm gonna get a set of red ones. And also how'd you get the needles to be blue also? Ah a couple more questions, i couldn't find the dual led lights, just single and quad? And has anyone tried this in a pre 91-92 camaro dash?
Old Apr 11, 2003 | 12:56 AM
bigals87z28's Avatar
Car: Check The Sig
how big of a pain is it to take off the dash to put these in.. i am also putting in white face guages... any one out there with white face and 87 dash set up?
Old Apr 11, 2003 | 01:04 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
http://www.superbrightleds.com/cgi-b...d=7190148.3601
or jameco.
Get as high an mcd as posssibel and also as wide an angle possible.
Also note what resistance youll need.
Old Apr 11, 2003 | 12:33 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
The needles glow blue with the LEDs. I need to get new ones without the orange stripe and they will be even more blue. I would go with the quads you can always dim them down if they are too bright. And yes the dimmer does work with them.
Brian
Old Apr 13, 2003 | 03:34 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
If you really want your needles blue.you can take them off,use paint thinner and take off that ugly orange stripe.but make a mental note of how big that stripe is because i found out the hard way that u cant paint the whole needle blue.i used model car paint so it would stick nice to the needle and be thick enought to give a good blue light.i painted the bottom of the needle blue exactly how the orange stripe was and i had blue needles.took me a couple hrs to do because i messed up the first time but after that it was really simple.also when u take out your needles write down where they were when u took them out so that when u put them back in they will give the proper readings.sadly guys i dont have pics because a week late my car got totalledin a accident so i didnt enjoy mine long enough but they looked sick
Old Apr 13, 2003 | 04:03 PM
nikh23's Avatar
i'm confused as to what orange strip you mean, isn't the whole needle just painted orange? And also what about camaros since our needles are painted white, anyone know if theres a better way to paint those things?
Old Apr 13, 2003 | 06:27 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
On firebirds, the needles are clear and somewhat prism shaped. The backside (underside) of the needle is painted a crappy orange color. The light shines thru the needle to light it up.
Camaro needles (82-90) are just solid plastic and lit by the reflected light from the trim bezel (black metal piece that surrounds the gauge faces).
Old Apr 13, 2003 | 06:41 PM
nikh23's Avatar
so for camaros simply painting the whole needle itself a different color would do the trick right? I was planning on doing white faced gauges, the quad LED lights, painting my needles red, and also painting the metal reflection piece on the cluster to white on the underside rather than the blue that it currently is to help reflect more light. does that all sound ok?
Old Apr 13, 2003 | 06:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Careful with what you paint the needles with. I've read on some "sport compact" oriented boards that the added weight of the paint on the needles makes the gauges read wacky. Some report that a "Sharpie" felt tip marker works. Do some research before doing this, though.
Painting the backside of the bezel white will help a little bit in reflecting more light. I did this when I installed blue LED's. I wonder if a more metallic slver color would be better?
Old Apr 13, 2003 | 07:28 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
hey 89blackGTA did you use both the bulbs AND the leds for your gauges? of so, why?
Old Apr 13, 2003 | 10:55 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
No, I have all LEDs. I just took that pic so you could see how much brighter the LEDs were than the regular blue bulbs.
Brian
Old Apr 13, 2003 | 11:27 PM
nikh23's Avatar
well i ordered the red quad led's for my car just a few minutes ago. I'm gonna be putting in my white faced gauges and doin the bulb replacement this friday i'll take some pics for the people who wanted to see it done on a camaro.
Old Apr 14, 2003 | 09:52 PM
FastElectrics's Avatar
Car: 89 Camaro RS
I'd like to see some pics when your done.. I'm looking at the quad blue ones for mine.. but no white face guages.. Though the singles ones look ok too...
Anyone take any pics of a standard white 194 bulb, with a blue LED beside it for a comparison?
Old Apr 14, 2003 | 10:01 PM
nikh23's Avatar
well what pictures would you guys want to see, i can take pictures of a standard 194 in the dash next to the quad red led, picture of the dash with all red led's, and then another picture with my white faced gauges when i go home for the weekend hopefully that should cover most of it
Old Apr 14, 2003 | 10:36 PM
Car: 89 Camaro RS
sounds great to me.. How about one picture of the dash with all 194's before you start.. this would give another good comparison.
Old May 11, 2003 | 01:51 AM
nikh23's Avatar
hey guys finally home for college. i'm goin to do the white faced gauges and LED gauges sometime this week right after i do my struts and shocks. I'll post my pictures as soon as I do it.
Old May 11, 2003 | 09:23 AM
dsaint1347's Avatar
I never noticed if the heater control on Firebirds were different from Camaros if they are not what is that then.
Old May 11, 2003 | 01:21 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I would also like to see some pics. I can't decide between either blue or red so maybe you can help me out.
Mike
Old May 11, 2003 | 04:15 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
dsaint1347
yeah that is the stock hvac panel on thirdgen firebirds, just not blue
Old May 11, 2003 | 05:30 PM
dsaint1347's Avatar
Nice!
I wonder if that fits in camaro's, I like the way the color stands out.
Old May 11, 2003 | 06:02 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I would still love to see pics of someone's in red. I think red would look good with my tan interior, but want to make sure first.
Old May 11, 2003 | 07:37 PM
nikh23's Avatar
i'll be doing red sometime this week, just gotta finish unpacking my stuff from school and then i'll get right on it
Old May 11, 2003 | 08:14 PM
Car: Check The Sig
HURRY UP NIK! SLOW *** SOB!!
Old May 12, 2003 | 04:08 AM
Slim89BlueRS's Avatar
camaro gauge lights
i have an 89 rs and i was looking at articles about converting to leds, and i am not advanced enough to do a full conversion so the bulb replacement that site offers is perfect, the camaro i have doesnt use the actual led thingys, they use the ones that look like rockets, look just like the old bulbs but with leds inside instead of the filament, so dont go buying 194 bulbs, this is the article https://www.thirdgen.org/newdesign/tech/leddash.shtml, so visit it and you will see what i mean, i am gonna do all the lights in my car, except the headlights because i will eventually do the conversion to xenon wannabees
later
Old May 12, 2003 | 05:34 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
just to let you know slim89bluers your link doesnt work....
Old May 12, 2003 | 08:33 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
so we can replace the blubs with led blubs and get the same effect as wireing in the lights like the tech artical says.
Old May 12, 2003 | 09:35 AM
CaysE's Avatar
take out the comma at the end
Old May 12, 2003 | 10:15 AM
DaGoat's Avatar
Brian
Quad isn't very bright either.
Old May 12, 2003 | 04:58 PM
Car: 89 IROC-Z
Engine: 383
Ok I have a quick quesiton. If you buy the quad ones off of that site, can you just plug them right in or do you still have to check the specific voltages and solder resistors to them? If you can just plug them right in, then what's the advantage of doing it the other way??
Old May 12, 2003 | 11:33 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Paul, I was just thinking the same thing. Why not save some work for yourself if you can just get ones the plug right in?
Old May 13, 2003 | 07:51 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
The advantage to making your own (like the tech article) is that you can use brighter LED's.
I've done both the DIY and the SuperBrightLED's (which are plug-n-play) and I like my DIY ones better. The unfortunate thing is the 10,000 mcd blue LED's aren't available from Jameco anymore and I haven't been able to find another source.
Old May 13, 2003 | 08:14 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
www.mouser.com
give them a ring the prolly got some that are the same they carry a huge amount of parts, especially hard to find stuff
Old May 17, 2003 | 12:39 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Hey Nik, have you gotten any pics yet???
Mike
Old May 17, 2003 | 11:41 PM
Car: 89 IROC-Z
Engine: 383
Also still waiting to see some red pics
I'd like to see some red dash lights soon please.
I think I'm going to do the DIY's since they are supposed to be brighter. I guess there is no way to do a quad setup with those right?
