Anyone running a line lock?
Old Dec 29, 2000 | 11:15 AM
MEANGREEN's Avatar
I'm interested in the TCI setup from Summit. It's cheaper than the one on my '95, which is the Hurst Roll Control. Anyone? Thanks.
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
(Prospective purchase)
Old Dec 29, 2000 | 01:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I've got the TCI Roll-Control. Want pics of it?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 29, 2000 | 01:18 PM
MEANGREEN's Avatar
Sure. Also, how was the install, pretty simple or was the kit complete. I know with the Hurst setup, I bought a kit to accompany it, which made install a breeze. Thanks, ya got a great website here, look forward to posting here regularly, you know, be a pain, etc
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
Old Dec 29, 2000 | 01:26 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I use the Biondo line lock. It's available from Summit and Jegs for less than $50. It took another $10 of fittings and two brake lines to install it.
Speaking of installation, if you splice the line lock into the line between the master cylinder and proportioning valve, the "Brake" warning light will light when you turn the line lock on. Kind of a poor man's indicator!!
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
My custom front marker lamp assemblies:
http://members.optushome.com/au/downunder1/misc/lens.html
Old Dec 29, 2000 | 01:43 PM
MEANGREEN's Avatar
Thanks, very helpful input, either system sounds good, just fixin' to build an '85Z28 and want some nice toys for it, just not the most expensive toys-haha! Thanx!
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
Old Dec 29, 2000 | 03:10 PM
5ubtle's Avatar
If you splice between the master cylinder and proportioning valve, the rear brakes are also activated. Why not just save $50 and hold your foot on the brake?
Old Dec 30, 2000 | 01:25 AM
Kevin91Z's Avatar
Mine works like that. My dad did it so I dont know. I gotta go search my website for pics.
Old Dec 30, 2000 | 06:59 AM
Willie's Avatar
NO!!! There are two lines between the master cylinder and proportioning valve. One controls the rear brakes, the other the front. I spliced into the front line leaving the rear brake lines untouched.
The reason the brake light turns on is because of the pressure differential between the front and rear brakes. This differential is extremely high when applying the line lock -- the front brake pressure is very high and the rear pressure is nil.
Willie
[This message has been edited by Willie (edited December 30, 2000).]
Old Dec 30, 2000 | 09:47 PM
5ubtle's Avatar
Ah, to be lost in the sixties (before braking systems were split into two independent systems).
My mistake Willie , a case of brain fade.
[This message has been edited by 5ubtle (edited December 30, 2000).]
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
Elliswon
Aug 10, 2015 12:33 PM
