Auto to Manual swap... need new chip?
Old Jun 7, 2003 | 11:16 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
ok I did some more research and noticed that the auto manual swap needs a new chip or memcal or ECM? which would be easiest. Also what am I looking for? will the 87 computer work without any mods? If so anyone selling one or a comparable one?
Old Jun 7, 2003 | 11:39 PM
ctandc's Avatar
You don't "need" a new chip. You will notice some weird things with idle every now and again after the swap.
You can just replace the PROM, but since it's soldered into the memcal as one unit, the "easiest" way is to just buy a same year PROM / Memcal for a TPI 305 T5 car.
HTH
Old Jun 8, 2003 | 12:14 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Then that would be my problem 85/86 didn't have t-5 tpi cars. They were all autos What should I do then?
Old Jun 8, 2003 | 07:12 AM
ctandc's Avatar
What year is your car? What engine and tranny did it come with? What's in it now?
Old Jun 8, 2003 | 12:59 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
sorry about that I thought I put all that in this post. I have another post up right now with all that. ok the car is an 86 305 TPI that came with the 700r. It now has a Tremec 3550 in it.
Old Jun 8, 2003 | 08:28 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
what is the difference between the memcal and the prom?
i have an 89 IROC with a stock 350 TPI and t56 from a 96 TA, will an 89 305 tpi/t5 memcal and prom work for me too, does it matter that i have a 350 and id be using a 305 memcal/prom? i would think it would be programmed differently, but i dont know.
is something like this what i would need? is this just a prom or is it a memcal and a prom?
http://www.slponline.com/view_produc...RTNUMBER=40026
Old Jun 8, 2003 | 09:44 PM
billyhoss's Avatar
305 prom vs 350 prom
u will need to use the 350 prom for ur set up because the 305 prom will not feed it enough fuel, 305 stock proms are set with #19 injectors and 350 proms have #22 injectors, so u will either need a 350/t5 prom or a custom one thats set for the right # injectors
Old Jun 8, 2003 | 09:49 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
So can I just goto a boneyard and try to find an 87 manual tpi TA/Z28 prom/memcal or just the whole ECM? Or will I have problems doing this and should just get a custom one?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
ambainb
Aug 29, 2015 12:43 AM
