Manual steering rack?
Old Nov 14, 2002 | 08:13 AM
Nasty_Bird_'90's Avatar
Just wondering if there is a manual steering rack out there for our cars. We here at the shop are building an 86 IROC, gutted, tubbed, no Power steering and it's no fun. If there is one out there please let me know! TIA
Old Nov 14, 2002 | 01:24 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
look for a s-10. i found mine in a 84 4cylinder s-10 truck
Old Nov 14, 2002 | 01:26 PM
Direct bolt in full manual rack? Sweet!! Thanx man.
Old Nov 14, 2002 | 04:34 PM
craig's Avatar
Car: 86 camaro
your saying rack but you mean the steering box right? the steering box is a direct boltin. some people on here have used the pitman arm from the s10 some say to use the camaro arm. i used the s10 arm and it works fine. i have 3.5" front tires and it turns easy. just want to be sure you're not refering to a rack and pinion type.
Old Nov 14, 2002 | 08:39 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
It's not a true DIRECT bolt it. Yes, the bolt holes line up. But, the support gussets in the box casting will contact the swaybar mount. You have 2 options: Grind the swaybar mount or clearance the steering box. I clearanced the steering box.
Tim
Old Nov 14, 2002 | 09:23 PM
craig's Avatar
Car: 86 camaro
sorry i don't have a front sway bar and didn't know. but he's drag racing and probably doesn't have one
Old Nov 14, 2002 | 09:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The S-10 manual box works fine. If you want an actual manual steering rack and pinion, No there is no easy way to install one. You could buy the tubular front crossmember from www.paracing.net with manual rack mounts installed. You then buy an aftermarket "Mustang II" style rack and install it.
Old Nov 14, 2002 | 11:14 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
PA sells a rack kit for their k member it includes the steering shaft and all.
Hotrodboba400
Dec 10, 2019 07:07 PM
Magman
Sep 12, 2015 11:55 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
