Manual vs. Power Steering?
Old Nov 22, 2002 | 02:06 PM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
After 237,000 miles and leaking the past 10 years, my power steering pump is gone. A couple of years ago I took it off and drove the car over a month wiht it off and it was extremely hard to turn.
Anyway, I am comtemplating the S-10 steering box conversion. How much effort is required to turn? I have the OEM 215/65/15 tires and a slightly smaller aftermarket steering wheel.
Also, how much is the cost differental of the manual steering box/pitman arm vs. a new PS unit?
Thanks,
Joey
Old Nov 22, 2002 | 03:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i like power steering
i would do what you have to to keep it
Old Nov 22, 2002 | 03:10 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
the manual box cost me $15 from a junkyard, i removed it.
Old Nov 22, 2002 | 05:20 PM
SuperchargedRS's Avatar
Car: Camaro of course
I have a Birtish car w/ man. steering, and it's a little tuff to turn sometimes, that car weighs about 1,800-2,000lbs, now think of that in a Camaro.
Old Nov 22, 2002 | 05:24 PM
Benny's Avatar
A new/rebuilt power steering pump couldn't be more than a couple hundred bucks and an easy install, I would just put one back in and be done with it, also a good time to change the hoses. I just replaced the pressure hose at $27.
Old Nov 22, 2002 | 05:39 PM
Joey1986Z's Avatar
Car: 1986 Z28
Supercharged: I had a British car as well with manual steering. A MG Midget to be exact. It was as easy as the Z28 to steer. It did have a big steering wheel. I also presently have a 1971 F100 Ford PU manual steering. It ain't so easy, but acceptable.
Old Nov 22, 2002 | 06:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can't compare a manual steering box with a power box with no hydraulic pressure.
You're not going to be able to spin the steering wheel with one finger while sitting still but as for driving the manual box is fine. There will be more turns from stop to stop because of the gear ratio required for a manual box.
You can pull a manual box out of 4 cylinder S10's for cheap. They're a direct bolt-in however the f-body pitman arm should be used.
Old Nov 23, 2002 | 08:25 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
It's not a direct bolt-in - but close to it. The steering box hits the driver's side swaybar mount. You'll need to either trim the mount or trim the box. The part of the box that contacts the mount is shown below circled in Red. This was on my 1990 IROC.
Old Nov 23, 2002 | 10:13 AM
ede's Avatar
ede
power to manual was a direct bolt in on my 85, but i don't need no stinking sway bar either.
Old Nov 23, 2002 | 02:16 PM
nbn792's Avatar
I drove my grandfathers 67 vette for a quick test ride after we replaced the clutch. It weighs close to what a thirdgen weighs, and i would never want to take that on windy roads, let alone around a parking lot at <10 miles an hour, not to mention how it likes to jerk the steering wheel around. However, i have friend with a 77 firebird and it wasnt nearly as bad, in fact it was quite tolerable. I would still however find another power steering pump for your thirdgen just because you may not like the feel of a manual, taht is unless youve tried one that was converted.
Old Nov 23, 2002 | 10:49 PM
DartByU's Avatar
Car: 92 Camaro RS
Manual steering is fine as long as your putt-putting around, or for a drag only car, I drive a Dodge Dart Sport that came with manual steering and it's a handful when 450 hp get's a little squirrelly on you, I'm going to change it over to a fast ratio power unit soon. Any modern sports type car should have it, period. Just bite the bullet and get your steering fixed the right way.
Old Nov 24, 2002 | 10:59 AM
bob8748's Avatar
I'm thinking about the manual switch also... Front sway bar is out of it as well. and goin electric water pump, only thing runnin a belt will be the altenator.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
