Strut Tower Brace
Old Sep 11, 2000 | 05:52 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Strut Tower Brace
I want to add a STB to my '86 Z28. I've got a dual snorkel air cleaner, though. Anyone got some pics of their set-up? I want to weld the STB myself. Thanks.
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Sep 11, 2000 | 06:23 PM
Matt86Z's Avatar
I don't have pictures up, but the STB and the DSAC will fit no problem. I have an '86 too, and I thought it would be a problem. I have the Edelbrock version of the STB.
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
Old Sep 11, 2000 | 08:33 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I bought the Edelbrock one for my 86 and i would not clear the A/C compressor. So now I have George Lara's STB.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/15/00)
There can be only one!!
Old Sep 12, 2000 | 07:55 PM
Metalifann's Avatar
I just put on my edelbrock strut tower brace on tonight. it made a huge difference. Night and Day.
Old Sep 12, 2000 | 11:18 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Does anyone know if the Edelbrock 3 point STB will clear an Accel SuperRam setup?
Riccioli Performance Motorworks
--RPM Racing--
Will be building 450 hp TPI 383 for my 89 IROC-Z this summer. Accel Super Ram, Edelbrock Intake and TB, Trickflow heads, MSD ignition, Hotchkis suspension, TPI Tech 700R4 tranny +many more goodies.
Old Sep 13, 2000 | 06:42 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have the edelbrock brace and the dual snorkel aircleaner, I can't get the one in let hose on (pass side). I did have to trim the a/c bracket slightly, you can't tell though.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Sep 21, 2000 | 07:48 AM
Nor Cal Mike's Avatar
As I recall, some carb equipped cars had the a/c compressor on the passenger side and some on the drivers side.I think it had to do with serpentine vs.V belt pulleys.
My car has V pulleys and the compressor is on the drivers side. These cars are the cars that experience clearence problems with Edelbrock STB's.
As for Hummers question, I've been pondering the same project.I think that a 1" O.D. tube will clear the snorkels and the hood. I layed a piece of PVC across the snorkels and gently closed the hood and it closed. It will be a tight fit. I was figureing on attaching it with removeable pins if the air cleaner is too hard to get off. You will then have to triangluate it to a hard point somewhere.
Nor Cal Mike
Red 84 Z28, stock L82 350, L69 carb, intake, and air cleaner
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's
Some are faster but mine's fast enough.
[This message has been edited by Nor Cal Mike (edited September 21, 2000).]
Old Sep 22, 2000 | 06:19 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I'll second George Lara's STB. It's a great piece and no drilling is required.
Check Out My Website
Sharons Virtual Junkyard
Old Sep 22, 2000 | 08:18 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Anyone have a picture of George Lara's STB? or a web page?
James
If the women don't find you handsome they should at least find you handy
Old Sep 22, 2000 | 04:56 PM
Wasn't George Lara's car the 84 Red Z28? If so, I remember the STB. It had the triangler braces that went up to the radiater support instead of the firewall. I think that I saw him posting over at Z28.com while Third Gen was down. You also might try searching Third Gen's archives under his name.
Mike
Old Sep 22, 2000 | 10:17 PM
Here's a pic of the Lara 2 point STB.
-Justin-
The F-body Model Kit Pictoral Archive (updated 9/18/00)
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
