aldl odbll for lt1
Old May 20, 2005 | 10:14 AM
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
aldl odbll for lt1
hi every one i need some help finding a aldl obdll diagnastic port for a 96 z28 camaro. i have a 96 5.7 lt1 in my 91 z28 and i need to get the odbll aldl so i can get the codes read off it. my engine is not running right. i have the signal and ground wire connected to the 91 aldl port but i have no way of checking it the way it is. i also have a lap top i was going to use but i cannot find the cable i need to hook it up to the aldl port of my 91. i was told you cant do it. or no cable was avalible for this. if any one can help or info on where i can get one would be great. thanks guys
Old May 20, 2005 | 12:13 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
No idea . I may be wrong but I only see three way you can do it.
#1. Figure out how the OBDII cables are made and custom make one for your own vehicle (hardest).
#2. Search salvage yards for a fourthgen OBDII connector and splice all necessary wires from your pcm and use a standard OBD II hook up cable.
#3. Convert to OBDI.
Sorry man, wish I could be more help =/.
Old May 20, 2005 | 01:15 PM
kevinc's Avatar
Car: 1982 Z28
Contact Speartech via www.speartech.com and see if he'll sell you the connector hood and a few crimp pins to go w/ it.
He sells an OBD-2 bench harness that uses the conventional OBD-2 connector hood.
Old May 20, 2005 | 03:48 PM
z91bowtie1's Avatar
Engine: 96 LT1 5.7
thanks i just emailed speartech to see what they got
Old May 20, 2005 | 09:13 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I have an obd II diagram around here somewhere, and a connector is $2.39 from dealership, but #2 is the easiest, as teh connector from dealer is just that, connector w/no wires/leads.
I'm really using 3 leads:
12+ (fuse)
2 grounds (spliced into 1)
serial data lead
2 rows of 16
numbereed left to right:
1-8
9-16
1. not used
2. serial data line class 2
3. not used
4. ground
5. ground
6. not used
7. not used
8. keyless entry program enable switch
9~13 not used
14. serial data line entertainment & comfort
15. not used
16. fuse output battery
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
greenyone
Sep 8, 2015 08:41 PM
L0tuS
Sep 4, 2015 11:16 PM
