Painting GTA wheels..
Old Jan 19, 2002 | 08:58 PM
Sauron91's Avatar
Is it possible? I have some golds, but I want some blacks..and it seems that just having them pro painted black might be cheaper than hunting down some blacks...anyone have any idea how expensive this might be?
Old Jan 19, 2002 | 09:01 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
do it yourself
heres how
http://www.gmtips.com/3rd-degree/dox...els/wheels.htm
Old Jan 19, 2002 | 09:18 PM
Sauron91's Avatar
Are you kidding me?
That's insane ;>
Old Jan 19, 2002 | 10:10 PM
fiream's Avatar
Engine: 400HP 350
I do you think a pro does it? just like that.
Old Jan 20, 2002 | 01:42 AM
Sauron91's Avatar
Yes but..I'd be afraid of..dropping the thing and wrecking the rims completely..
Old Jan 20, 2002 | 02:53 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Ok... that way could work, but here is an easier, way more affective way.
***DO NOT USE SAND PAPER ANYWHERE ON RIMS***
1: You need a can of aircraft stripper, a few paint brushes, some duck (qwak ) tape, a spray nozzle(pump kind like on windex... any one from anything will do) and some clearcoat.
2. Start by taping up the INSIDE honeycomb part of the rim with duck tape.
3. Insert the spray nozzle into the can of aircraft stripper, and spray HEAVILY over outer polished part of rim. It will be thick and globby, but that is good. Make sure the entire rim is covered, VERY HEAVILY. ***you can skip step 2 if you would like to strip the honeycomb part of your rim aswell***
4. Ignore the directions on can, and let sit for 1-2 hours on rim, swirling stripper around on rim every 15-20 mins with paint brush.
5. Once the time is up, use a paint brush and swirl all of the stripper, making sure no pieces of clear coat are left on the rim. Once your sure its good, remove the tape on the inside, and hose off completely. Dry with towels.
6. Paint the inside of your rim, if doing so, with appropriate paint, as per directions on can. Make sure to tape off aluminum area!
7. Now, proceed to polish the outer rim with your preferred metal polish (I prefer Mothers) ***note: you are now at bare aluminum, and nomatter how much you polish, your rag WILL ALLWAYS TURN BLACK!!!***
8. After fully polished and ready to go, make sure the rims is clean and free of any polish residue, and clear coat your rim. Make sure to get a compatible clear coat, and follow directions on can!
9. Put rims on your car when COMPLETELY DRY. If the clearcoat and/or paint is still tacky, brake dust will embed itself in there, and youll have to start over.
10. Drive around town showing off you better-than-brand-new rims!!!
This process isnt as hard as it sounds... I dunno, its kinda fun to do... its the best way that I have found to do it!
Good Luck!
Old Jan 20, 2002 | 03:12 AM
Sauron91's Avatar
Hey 88..think I could do that with the tires still on the rims? Hoping to get all of this done on a weekday if I do it myself..that whole leaving it up on blocks with no tires is too much for me ;>
Old Jan 20, 2002 | 03:23 AM
Yeah, I left my tires on there. Just try not to get any on the tires. I got some on there, and it didnt hurt the tires at all, but some say it can. And the tape wont stick to the tires(trust me ), so youll wanna use the paint brush to apply it to the very outside lip of the rim. Thats also why I like using the sprayer, you can make it go exactly where you wanna!
Street Lethal
Apr 30, 2019 12:14 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
gta power
Convertibles
Sep 23, 2015 09:32 AM
fcorallo
Aug 20, 2015 11:28 PM
LilHot
Aug 19, 2015 10:02 AM
