Upper Panhard Rod
Old Jul 19, 2003 | 05:55 AM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
Upper Panhard Rod
would this work on a thirdgen?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2423790746
c-ya
zed
Old Jul 19, 2003 | 07:15 AM
ronterry's Avatar
Car: '94 Corvette
Personally I would just box the stock track support...
Even then I don't think it's a hugely critical component like the track/panhard bar.
Ron
Old Jul 23, 2003 | 05:23 PM
MdFormula350's Avatar
i e-mailed the seller to see if it would fit a 3rd gen, if not maybe this place could make some.
update:
the seller said, he doesnt think it will fit a thirdgen, and i responded is there any way to make one for a thirdgen, and he responded we will look into that.
Old Jul 23, 2003 | 09:00 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just buy a new Panhard Bar from Spohn Performance to replace the stock bar.
Old Jul 23, 2003 | 09:35 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Thats the upper brace bar. Spohn doesn't make one.
Old Jul 23, 2003 | 11:53 PM
sllt1776's Avatar
Car: 89 Iroc-Z
cool, let us know what the answer is
Old Jul 25, 2003 | 04:25 AM
85TPI400's Avatar
I have been curious about when someone was going to make something like this, I was asking one of the guys from slotcar racing if they had anything in the works like this, they dont at this time but said if there was enough interest in these that he would consider making them. There is definitely something wrong with this set up in question, First of all, where is the exhaust on this car?
Second, the angle is different than the thirdgen has to clear exhaust.
Old Jul 25, 2003 | 04:28 AM
85TPI400's Avatar
Here is how ours looks! What would be great is if someone made one that ran almost parallel with the lower one closer to the center of the rear and then angle upward to give enough clearance to run big true duals through that area.
Old Jul 25, 2003 | 10:56 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Something like this?
Attached Thumbnails Upper Panhard Rod-undercarriage-after-removal-strange12b
Old Jul 26, 2003 | 02:46 AM
85TPI400's Avatar
Something just like that!
Do you know what year car that is on, if not a third gen do you know if that company makes them for our cars?
Old Jul 26, 2003 | 02:57 AM
Zepher's Avatar
I have no clue about that bar. That is a 4th gen btw.
My friend just installed a similiar exhaust on his car with the stock bar in place, so I know it can be done.
He did dual 3" with an X-Pipe, over the axles, into two small mufflers.
Old Jul 28, 2003 | 05:15 AM
MartinCadek's Avatar
just to throw this in the air , why wouldn't that ebay bar fit ???
the axles are the same and the frame rails should be in the same place as well , maybe a few bolt holes will have to be elongated etc... but there's not that much differnt stuff back there on 4th gens , I'll compare my 85 and my dads 95 firebirds this weekend to see but IMHO it should fit
only place where it might hit is the exhaust but 4th gens have the pipes routed exactly the same as us so even there I doubt it would be an issue.
Old Jul 30, 2003 | 03:31 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Granatelli makes the upper bar. Check www.granitellimotorsports.com
Old Jul 30, 2003 | 04:45 PM
zed's Avatar
zed
the link dosen't work street.......
Old Jul 30, 2003 | 07:54 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Sorry www.granatellimotorsports.com
Old Jul 31, 2003 | 11:01 AM
zed's Avatar
zed
The upper Panhard Rod they have is just a boxed stock one. i like the look of the tubular one i posted at first....... and they want $225 for it. I could have mine boxed for quite a bit less.
c-ya
zed
Old Aug 3, 2003 | 09:54 PM
JerseyIrocZ's Avatar
Car: 89 Iroc
Engine: 5.7 liter (L98)
Transmission: TCI 700r4
don't buy it box it yourself. just take it to a welder and he will have no problem doing it for a lot less then 225. Or try and get someone to make them tubed if they did make them i would buy one for mine. I have nothing else to replace or make better back there except for the upper bar.
Old Oct 10, 2003 | 08:47 PM
Spdfrk1990's Avatar
I like tha 1 in the pic zepher posted would help clear the exhaust mine is real close to my stock 1. I didnt see it on that web xite
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
