what ignition wires?
Old Oct 15, 2004 | 02:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i need new spark plug wires, my stock ones burned on my headers.
is it worth it to upgrade to msd wires? is their a major difference between the 8mm and 8.5's?
thanks!
Old Oct 16, 2004 | 12:16 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
no one knows?
Old Oct 16, 2004 | 12:19 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is it that know one knows or is it becuase no one could reply due to little issues TGO has been having? Hmm, I'm not certain.
So get factory replacements from the store.
Old Oct 16, 2004 | 12:55 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Get msd.I have accel and am going to switch to msd with new engine
Old Oct 16, 2004 | 01:42 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
On a basically stock engine, or something close to it anyway, you won't notice any difference over just stock replacement wires.
Old Oct 16, 2004 | 02:34 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I bought some MSD wires that are for the late 80s pickups, and they're a good fit with an HEI and headers. If you're looking for a set that's pre cut with 90deg boots.
Just something I thought I'd pass along.
Old Oct 16, 2004 | 02:57 AM
Air_Adam's Avatar
The best wires to get if you have headers are for a '75-81 Z28 or a '75-82 Corvette. They both had the wires routed the same way you'd route them for headers, so they would be the right length for what you need.
EDIT - Don't go earlier than '74, because then you will be dealing with points distributors.
Old Oct 16, 2004 | 07:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks for the tips, i picked up a set for the 80's pickups as well, cuz they were in stock didnt wanna order the 70's vette wires. they fit nice and with some looms and zipties, clear headers just perfect
Old Oct 16, 2004 | 08:55 PM
Car: '85 IROC
Engine: LB9
Hooraay!
When I got my MSD wires, I measured the resistance and they were so close to being on spec that I could tell the length of the wire by the resistance.
Ya gotta love the way a new set of plug wires smells when you open the box too, it smells like success.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
