Q Logic Sub Box
Old Apr 24, 2001 | 04:42 PM
350iroc-z's Avatar
Q Logic Sub Box
The thing that i am talking about is the custom enclosure that fits perfectly in thridgens. They are kinda costly but they look to be built out of plastic. Does anyone know how good these sound or how firm they are. They look very nice but I would rather have something functional then nice looking.
www.350iroc-z.com
Old Apr 24, 2001 | 09:48 PM
92fire-audio's Avatar
The box is made out of particle board, not mdf board and the cover plastic thing rattle's no matter how well you put it on. I don't even use mine because it sounds so horrible. The box fits good though and if you have small airspace subs they should sound nice. I just sprayed undercar rubberizer in the box and put polyfill in to make up for the box bieng made out of particle board. If you can get it for less than $200 it's probly worth it, but it it's over that just have a custom shop do the job. It will be thicker and sound better..
Old Apr 25, 2001 | 08:08 AM
purpleworm's Avatar
I have one from exciter sound. It is made of MDF and the new ones are carpeted. It came in 2 peices and it is about 2.9 cu/ft total. I like it!
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
Old Apr 25, 2001 | 08:59 AM
350iroc-z's Avatar
I was looking for a smaller box. I know that the q logic ones have the right amount of space for the subs i am looking at. I was hoping that they would be made of mdf and wouldnt have rattling problems. Does anyone else know of a place that sells a small box that will fit nicely in the well. The size i am looking for is between .6-.75 cu ft
www.350iroc-z.com
Old Apr 25, 2001 | 09:27 PM
Slow 89 Iroc's Avatar
I have the Q-Logic box in my Camaro and it does not rattle at all. The box is very heavy duty....you will not be able to blow it out with subs even though it is made out of particle board. It is sealed and carpeted and the top fiberglass cover makes it look professional. I am running 1000W amp pushing 2 12in Earthquake subs, the box is rock solid. Fill it with polyfill and it will accominate almost any 12in sub you can think of.
Old Apr 26, 2001 | 04:10 PM
Polecat's Avatar
A guy that works here with me has one in his '94 Formula, and has 2 Solo 10" woofers off an Kicker IX1302 amp, and it sounds awesome.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Apr 27, 2001 | 04:46 PM
T/A Man's Avatar
Qlogic makes a couple of 10" tube enclosures that would drop down in to the trunk very nicely. Your choice is .65ft or 1.15ft.
Old Apr 27, 2001 | 05:09 PM
350iroc-z's Avatar
I saw those as well. I wasnt sure if they would fit into the well or not. Esp the larger 1.5 cu/ft one. I am not sure if I want to go with 1 10" or 2 10" yet. I have an amp that produces the best results at 4 ohm mono. I thought I could best achieve this using 2 dvc 4ohm 10" subs
www.350iroc-z.com
Old May 1, 2001 | 06:34 PM
blackstripes's Avatar
i have the q-logic box in my 92 camaro. i love it and i have never had any problems with it the plastic rattling. by the way it also looks great because the plastic molding looks almost factory. was kind of expensive though...
Old May 1, 2001 | 07:25 PM
DJSexay's Avatar
The issue with a particle board box vs a mdf box is not "blowing" the particle board box out, but that the particle board wil flex some, and any flex in a box will result in less bass.
Just my .01 (I can't afford a full .02 anymore )
mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
Old May 2, 2001 | 11:37 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Anyone have any pics of the Q-logic box, installed?
Old May 3, 2001 | 12:11 AM
jobryan26's Avatar
Here's a pic of a Q-Logic in a 4th gen T/A. It looks almost identicle to the 3rd Gens. I had one in my T/A and I really liked it. I never had any problems with and wouldn't have a problem with owning one again except I have 3 12's in my car which is why I got rid of it in the first place.
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Member at kyfbodies.org
[This message has been edited by jobryan26 (edited May 02, 2001).]
Old May 3, 2001 | 12:31 AM
jobryan26's Avatar
Found a pic of a 3rd Gen
'87 Trans Am:
(Engine)
305 TPI
JET Fan Switch
TB Bypass
Accel Super Coil
(Stereo)
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
