ls1 with stock radiator?
Old Feb 16, 2005 | 03:04 AM
Kandied91z's Avatar
what modifications would be necessary to utilize a stock thirdgen style radiator? i have a becool that i'd rather modify then sell off.
Old Feb 16, 2005 | 06:55 AM
kevinc's Avatar
Car: 1982 Z28
No radiator mods, just use the right hoses to connect the LS1 to it.
I used a 2001 F-Body upper rad hose, no PS cooler; lower is a 2001 Silverado 5.3L piece. Minor trimming only, no hacking needed.
Old Feb 16, 2005 | 03:25 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
What he said
Old Feb 16, 2005 | 04:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you'll find after installing the 2001 Silverado hose that it hits the idler arm and looks kinda cruddy.
since looks and clearance count in your case, get a gates hose:
GATES Part #21505
i donno what its for, but it works PERFECTLY. and doesnt rub.
also the LS1 has a steam release vent... normally it goes into the radiator..
you COULD tap the existing plug on the becool radiator and then put a fitting in, then run 1/4" line to it.
or.
since yours is alum, id just cut off the existing fitting, have someone TIG on a 1/4" nipple, polish it back up, and it'll look better then factory.
i'll take some pics of the hoses and stuff when i get a chance.
Old Feb 16, 2005 | 05:45 PM
Kandied91z's Avatar
sounds good, appreciate the feedback!
Old Feb 16, 2005 | 08:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok, heres some pics... i didnt get them all thru my email yet, but heres what i have:
heres the first pic of the silverado hose.. you can see my complaint about it.. it hits the idler arm mount.. it did come with this corragated, "protector" crap... but it looks like ***... its only on there so i can run the car while i was looking for other options...
Attached Thumbnails ls1 with stock radiator?-c-documents-settings-cat
Old Feb 16, 2005 | 08:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok, heres the next pic.. same hose... i held the camera down low between the radiator and motor, you can see where it hits better...
Kandied91z's Avatar
as long as it works that idea will do. just need to know it's possible. thanks.
Old Feb 16, 2005 | 08:45 PM
Kandied91z's Avatar
ahh, yes i see it, thanks for the pictures.
Old Feb 16, 2005 | 08:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok, notice that small hose in the first pic? thats your coolent bypass/ steam release whatever hose... basicly it lets the air out of the head so steam doesnt form/collect there.
i screwed a nipple adapter in there and hooked it up.
naturally, as soon as the car warmed up, the damn thing cracked... i used some epoxy to fix it for now... im just ordering a generic aftermarket alum radiator soon... i'll get a bung tigged on it... much like i suggested to you.
Old Feb 16, 2005 | 08:47 PM
Kandied91z's Avatar
yeah i figured i'd have to go that route but i was curious if there was temp fix for the situation just to get up and running to test the combination first hand.
i appreciate it.
Old Feb 16, 2005 | 08:49 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
and incase you're curious where the other end of that coolent bypass hose is, here it is..
i removed the throttlebody part (like thethrottle body coolent bypass mod) and when i say remove it, i mean, i cut it off, and ground/polished until you cant see it was thereanymore... that gave me enough room to run the hose under the throttlebody, less visible that way.
heres a pic:
you're on the drivers side of the car, looking down under the throttlebody.... you can see the TPS in the pic for location ref...
Old Feb 16, 2005 | 08:50 PM
Kandied91z's Avatar
very nice. thanks.
Old Feb 16, 2005 | 08:52 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Cool. Thanks for posting the pics. Very helpful to know ahead of time. I should be yanking out the existing engine within a week and be into this soon myself. I will be posting up questions along the way I'm sure
Old Feb 17, 2005 | 01:58 PM
kevinc's Avatar
Car: 1982 Z28
GATES Part #21505
Sweet, thanks for sharing that part#. Mine doesn't hit the idler arm, but it rests right between the two bolts that hold the idler arm bracket to the frame. If this new hose routes more cleanly I'm all over it.
Old Feb 17, 2005 | 02:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
id chalk up the diff to probly being diffrent companys..
i have pics of the new hose but they didnt showup in my email.... i'll resend them as soon as i go out there....
Old Feb 18, 2005 | 02:07 PM
CamaroCain's Avatar
Car: 88 Camaro
Dude are you running and LS1 k-member or are you running some conversion mounts...I was wondering if those hoses would work the same with the conversion mounts since they move the engine rearward some. Thanks
Old Feb 18, 2005 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the engine SHOULD stay in the same place no matter what... you dont want to move the bellhousing location, jsut make the mounts match...
ofcourse, that may or maynot be the case... i donno since i cant measure it in comparison to other LS1 3rdgens....
either way, the hoses should still work..... they are flexible...
Old Jan 11, 2009 | 05:41 PM
dasferret's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock open 2.73's
Re: ls1 with stock radiator?
Just to give some help, the Gates hose checks out as a 1983-90 f-250 and f-350 hose
Old Nov 16, 2009 | 07:17 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Ok so I just left Napa for the second time, trying to figure out what lower radiator hose will work. I originally bought the Gates 21505 or whatever the number was, for the 1990 7.5L Ford, and it is at LEAST
1/4" bigger in diameter than it should be. So now I returned it and got the 5.3L Silverado hose but its not curved like the stock one or the Ford hose, so I think its going to hit the idler arm like posted above. Where are you guys getting the right size hoses from?
Old Nov 16, 2009 | 08:06 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
With stock LS1/LT1 rad, you ca use stock f-body hoses, otherwise i used an accordian universal hose with my thirdgen rad/LS1 pump
Old Nov 17, 2009 | 09:29 AM
BlueZee28's Avatar
I'm using the radiator from my car. I guess if this 5.3L hose doesn't work I will have to run a universal one too. I just can't figure out how people are using that Ford hose when the one I got was way too big in diameter.
Old Nov 21, 2009 | 09:15 PM
BlueZee28's Avatar
Ok I am thinking that the only good way to use the lower hose is to get a flexible hose that you can bend into whatever shape you want. I tried buying that Ford lower hose and the diameter was WAY too big. I just put the Chevy 5.3L lower hose on yesterday and it fits like crap, it doesn't just hit the idler arm, it's pushing in a good chunk of the diameter. I'm going to have to take this one off and get a flexible hose...
Old Dec 3, 2009 | 05:39 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Hmm Id love to know whats up about the lower coolant hose too. Are you guys sure 21505 is the right number?
Old Dec 4, 2009 | 09:48 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I had to cut my Ford lower hose. Eyeball it and you'll see that both ends need to be trimmed. Mine is snug as it should be and fits perfect now
Old Dec 4, 2009 | 09:51 PM
Car: 1987 GTA
Transmission: 4L60e
Stole this from my old post:
Originally Posted by 3.1EyeCandy
We worked for a few hours this last weekend, but I took some pictures of current state and thought to post. We started by trying the stock 2001 upper and lower radiator hoses on my combo (ls1 + 3rd gen radiator)....this doesn't fit. Others have apparently managed to massage the lower hose on, but I couldn't see spending that much time and frustration - there had to be a better way. The upper (stock 2001 w/out the power steering cooler) wasn't long enough.
So, thirdgen to the rescue. These are the numbers you need:
Upper: Gates #20893 (Early 4th gen Camaro w/v6)
Lower: Gates #21505 (83-90 Ford F-250 and F-350)
The upper fit fine, but looked a little more factory after trimming an inch off the radiator side. The lower...looked twice the size as the 2001 camaro unit and I honestly thought I'd paid good money for a part I was going to throw away. Never the less I trimmed it where I thought it might help. This was all that I trimmed...
And boy does it fit great!
Old Dec 4, 2009 | 09:55 PM
BlueZee28's Avatar
K, I guess I'll buy another one and try to hack it up. Thanks Jon.
Old Dec 4, 2009 | 10:53 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Thanks 3.1!
Old Apr 29, 2010 | 10:08 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hmm, maybe in the states gates hoses are still around but here in Ontario, Canada no one carries gates anymore, its all prestone or dayco.. i got a dayco hose part number 71215 which is 83 to 89 F250 7.5l [in 1990 ford hoses changed half way through the year from one peice to a two piece lower] and there is seemingly no way it will go on..... from the pictures posted of the gastes hose cut above you can see that the ends are enlarged and the rest of the hose is a smaller diameter so that it fits when you trimm the ends off.... with the dayco hose it is the same diameter throughout and no amount of trimming will make it fit nice enough... at least for my standards, it just too large a diameter of a hose. My suggestion is to STAY AWAY from the dayco hose. im not sure what ill do now, but i will post up my solution when i get one
Old Apr 29, 2010 | 10:49 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
another upper hose that fits perfect is the upper hose for a 1989 tta. i dont remember the part number but it works great.
Old Apr 29, 2010 | 02:19 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I'm having the problem with the f250 lower hose too. Mine is a Prestone hose and is the same diameter throughout the entire hose, it isn't enlarged on the ends and smaller in the center. There is no way this hose will work, it is too big and even if it were smaller, the bend seems way different than 3.1 Eye Candy's, I guess I will have to order the Gates one online then
Old May 4, 2010 | 11:46 PM
Mike Massey's Avatar
stop spending money on hoses and get a ls1 4th gen lower coolant hose instead
Old May 5, 2010 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I did. It didn't fit the 3rd gen lower radiator outlet.
Old May 5, 2010 | 11:19 PM
I apologize i forgot had my radiator modded and reduced for the ls1 lower hose . I got upset tryin to find one that would work ha my "old" rad modded
Old May 8, 2010 | 10:06 AM
timmyboy's Avatar
Car: 91 z
Axle/Gears: moser 9"
That ford f-250 hose fits like crap!!! I would never use it way to big in diameter. To bogus looking for my swap. There has to be a better hose out ther!!
Old May 9, 2010 | 06:01 AM
timmyboy ur swap is lookin good .you might could try a 4th gen lower rad hose but it will be xtremely tight fight over the nipple. : but if u get it on you will be happy with the fit. u may want to try a 5.3 truck hose also there also slight diff between hose manufacturers
Old May 9, 2010 | 09:22 AM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
I used the 4th gen rad and hoses worked great dropped right in. Heater hoses as well.
Old May 9, 2010 | 09:21 PM
timmyboy's Avatar
Car: 91 z
What year 5.3 truck motor?
Old May 9, 2010 | 09:41 PM
dont hold me to it but try 2000 should get close i tried one but it was too close to sway bar mounts for me but u may want to check it out it come with a convoluted shield
Old May 16, 2010 | 02:03 AM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Hey I tried the Ford one and it was not a fit!
the rad I'm using is a Be Cool rad..is there a hose that
is special for this app..
The 5.3 was not right either, may try it again!
Any ideas or adjustable hose style I should be looking up!
Old May 16, 2010 | 08:42 AM
Pocket's Avatar
Car: 91 Trans Am
Yall who are having problems with the Ford hose, post a pic of the problem areas
Old May 17, 2010 | 08:14 PM
I'll try again to get a pic on here..
sorry about no pictures, have one on the cell I will try right now
Old May 18, 2010 | 03:35 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Anyone consider a 360 deg swivel thermostat housing from byunspeed. Also Katech makes a straight outlet aluminum anodized thermo housing too. If you are willing to spend the money these might be good options.
Old May 19, 2010 | 08:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Jegs and a bunch of other places sell inline radiator hose drains for about $20. It's a great option because it lets you splice together 2 separate sections of hose, which open up a world of installation possibilities. It's also a lot less messy than using the stock radiator drain. And... if you're like me and run a Griffin racing radiator with no lower drain, this makes life way easier than pulling the hose to drain your coolant.
Old May 27, 2010 | 05:15 PM
Shift06's Avatar
http://img707.imageshack.us/img707/6379/1135117.jpg
The hose I got (Prestone brand) looks to be shaped differently than the gates piece, and it does have flared ends, the whole hose is one size (too big )
Old May 27, 2010 | 11:50 PM
is that the proper hose you have in the pic..cuz mine is different. Try to get a pic of it and also thought of 45 degree elbow on the straight of the Be Cool rad. the lower hose is the same height where the base of the battery sets.....
One other question...on the water pump, What is the supply line to the heater coil? 5/8 and 3/4 I believe the size is....I'm using a manual shut off and try that instead of a vacuum one..tks for the help
Old May 28, 2010 | 05:24 AM
Shift06's Avatar
It's a lower rad hose for a '90 F250, 7.5l.
Old May 28, 2010 | 11:32 AM
Got some pics for you Pocket!
I have a 89 F-250 7.5 lower rad hose!
The other pics are what the hose area looks likels1 with stock radiator?-0528101123.jpg
Old May 28, 2010 | 02:00 PM
hey budd, is that a stock radiator!..I have my pics on here and your rad looks like the lower hose goes lower...
The hose would work if I put a coupling in there for the lenght you needed for the lower connection....I would shorting that piece maybe....well ...its hot rodding..right..lol
Old May 28, 2010 | 02:20 PM
Shift06's Avatar
Yeah wow my hose is nothing like that. Mine is short and completely different bends. Was there a change between 89 and 90? I thought someone said the hose required was from a 90? Apparently not lol.
