5 Point Harness and Roll Cage, I need pics on where the Harness mounts!
Car: '82 Z28
Probably just use the factory spots for the lap belt, the middle nut crusher though you probably need to drill a hole and use a couple 3 inch diameter washers so it doesn't pull through the floor.
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I used the factory seatbelt mounts for the lap belts. The center belt that runs up between your legs is mounted to the floor under the seat. I used some steel plate, welded squares on each side of the floor panel and drilled a mounting hole. If you do a search for my name, I have posted many pictures of my set-up...
Car: 91 firebird now
Transmission: 5 speed
ambainb
Apr 25, 2016 09:21 PM
