5 Point Harness and Roll Cage, I need pics on where the Harness mounts!
Old Dec 30, 2002 | 03:45 PM
JucinGTA's Avatar
Hey I have my cage but Im clueless on where to mount the Harness, can any of you help me out with some pics?
Old Dec 30, 2002 | 05:51 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
this is Stephen 87 IROC's car..
Attached Thumbnails 5 Point Harness and Roll Cage, I need pics on where the Harness mounts!-0000rollbar5.jpg
Old Dec 30, 2002 | 05:54 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
and this is transam84's
Attached Thumbnails 5 Point Harness and Roll Cage, I need pics on where the Harness mounts!-0000rollll.jpg
Old Dec 30, 2002 | 08:31 PM
JucinGTA's Avatar
K, now I know where it goes to the Bar, but how does it mount to the Floor? Pics?>
Old Dec 30, 2002 | 09:43 PM
EvilCartman's Avatar
Car: '82 Z28
Probably just use the factory spots for the lap belt, the middle nut crusher though you probably need to drill a hole and use a couple 3 inch diameter washers so it doesn't pull through the floor.
Old Dec 30, 2002 | 11:22 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I used the factory seatbelt mounts for the lap belts. The center belt that runs up between your legs is mounted to the floor under the seat. I used some steel plate, welded squares on each side of the floor panel and drilled a mounting hole. If you do a search for my name, I have posted many pictures of my set-up...
Old Dec 31, 2002 | 12:56 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
I searched and could not find a thing.
Old Dec 31, 2002 | 02:55 AM
MdFormula350's Avatar
nice pics
Old Dec 31, 2002 | 03:03 AM
92GTA's Avatar
Old Dec 31, 2002 | 11:48 AM
JucinGTA's Avatar
Thanks man How many point cage is that?
I like that Cage style way better by the front seats, It would be better for us tall people.
Old Dec 31, 2002 | 12:29 PM
92GTA's Avatar
It's a full 12-pt cage. More pictures are in my sig, just click on 1991 Firehawk...
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
z28addict8490
Aug 7, 2015 08:48 PM
