Flow numbers for aftermarket TPI intakes?
Old Mar 2, 2002 | 10:05 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hey guys, I need flow numbers for aftermarket intake bases. Some people say the Accel base flows the best. I will need to use the S/D Vortec TPI base, (only if I dont sell my fastburns to help buy the new Dart Pro-1 heads). What about the Edelbrock base and the TPIS "big mouth" base? Any info would be appreciated!!
Thanks,
Mike
Old Mar 3, 2002 | 01:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm having an impossible time finding this info myself. Everybody here says that all the aftermarket bases are pretty much the same, and everybody on corvetteforum swears up and down that the accel is substantially better than the TPIS and edelbrock. Nobody in either place seems to be able to offer much in the way of proof unfortunately. I've got the runner diameter for the accel, as well as stock, but not for the edelbrock or the SDPC intake. I've got flow numbers for the accel base in the tech setion of iroc.fbody.com, along with flow numbers for stock stuff, but nothing for edelbrock or SDPC.
Old Mar 5, 2002 | 03:06 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
anyone else have any more info on aftermarket bases?
Old Mar 5, 2002 | 03:48 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Stock base, stock runners 198.72
Stock base, Accel runners 213.5
Accel base, stock runners 215.8
Accel base, Accel runners 232.5
Accel base, Accel Super Ram 240.2
Accel base, extruded Accel runners 243.2
Extruded Accel base & runners 266.9
Stock base, Accel Super Ram 220.67
Stock base, Extrude Accel 217.11
Stock base 222.5
Accel base 251.5
Extruded Accel base 275.8
Stock runner 203.2
Accel LTRunner 242
Super Ram runner 289.2
AS&M long tube runners 260
Taken at 28" H20
I found this a while back on the boards. So I can't say how correct if is. Figure it'll give a starting idea though.
David
Old Mar 6, 2002 | 06:47 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Badass!! Thanks Black 91 Z-28! Any flow data for SLP siamese runners? I have a dumb question. Is the Accel base for LTR TPI setups the same base they sell with the Super-ram? Oh yea, my 91 Z-28 is black also, nice car!!
Mike
Old Mar 6, 2002 | 08:29 PM
Jim85IROC's Avatar
Those numbers came from the IROC homepage. I posted them there about 3 or more years ago, and at some point probably copied them here. They originally came from the December 98 issue of Hot Rod. No edelbrock base info tho
Old Mar 6, 2002 | 09:41 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The aftermarket Accell, Edelbrock and TPIS bases are all very similar in design and will flow approximatelly the same. I have an Edelbrock base and a SDPC vortec base and the Edelbrock base looks like it will flow more air then the SDPC base. The runners in the Edelbrock base are larger in diameter then the SDPC base and there is more material around the runners in the base to allow for porting. The SDPC base also has some airflow restrictions where the fuel injectors protrude into the air stream. Overall I believe the aftermarket bases designed for the conventional SBC heads will support more airflow and power then the SDPC base designed for the vortec heads.
Old Mar 7, 2002 | 07:21 AM
Jim85IROC's Avatar
I don't suppose you could mic the two bases to get an accurate runner diameter, could you? As usual, there's conflicting information all over the place. Some say the SDPC base is the same as the edelbrock, and others say it's the same diameter as stock. Some say the edelbrock is is as big as the Accel, others don't. You... yes YOU, can put the rumors to bed.
Old Mar 7, 2002 | 11:37 AM
87transam5.7tpi's Avatar
does anybody have flwo numbers for a siamesed stock intake?
Old Mar 8, 2002 | 04:58 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
So far, it seems like the Accel base flows the most! Does anyone know the size of the intake ports on the Accel base (the ones that mate the heads) ? Has anyone run into problems with the Accel base? How does the Accel base compare to the TPIS "big mouth" as far as flow numbers go?
:lala:
Old Mar 9, 2002 | 09:10 AM
BlackZee's Avatar
The TPIS Big Mouth manifold is made by Edelbrock.
Old Mar 9, 2002 | 02:07 PM
camaro6spd's Avatar
wait, so the LTR out flowed a superram??? I think my sig is too big now huh??
Old Mar 9, 2002 | 03:15 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
From what I saw, if you look closely, the LTR setup that flowed better than a super-ram was an Extrude Honed LTR setup. So everyone is in agreement that the ACCEL base with SLP runners is the best choice as far as flow goes?
Old Mar 9, 2002 | 08:24 PM
dnovotny's Avatar
I hate posting something critical, but when people choose to not use their brain, and they post BS, I can't restrain myself.
camaro6spd, before you post BS, look carefully at the flow numbers. The base or the runners can be a restriction to flow. Thats why an extrude honed base and runners will outflow a SuperRam that doesn't have an extrude honed base! Whatever flows the least will limit and pretty much determine the overall flow of a system. Anyways, do a little thinking before you put your foot into your mouth.
Later, Dave '01 WS6 T/A, '91 GTA, '91 T/A
Old Mar 10, 2002 | 09:27 AM
ImportsRsloths's Avatar
Lets see....
LTR set-up....
Fully ported plenum, Extrude honed and ported SLP runners, Extrude honed and ported Accel base = EQAULS = Superram w/ stock base (no porting)
****AND**** FULLY PORTED, extrude honed super ram and extrude honed ACCEL base EQUALS wait no LTR setup can flow this much
Old Mar 10, 2002 | 11:47 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Look guys, I am an adult, as I hope most of you are. I'm just trying to figure out what LTR combination flows the best and I'm asking help with that before I fork out more dough! I want to stay with the LTR setup. I have fastburn heads, but before I spend alot of money on head work, I need to find the best LTR intake combo. The reason I'm in this situation now, is because I've heard negative things about the SDPC Vortec TPI base. If the Accel base flows the most ("out of the box"), then I will sell my heads and choose a non-vortec style head. All of this is in my quest that you "can" put 400+ ponies to the back wheels with a LTR TPI setup naturally aspirated. I know that I could do this very easily with a mini-ram or a super-ram, but I'm sticking with the LTR setup, therefor I need the highest flowing base and runners. Has anyone used TPIS runners on their motors? Again, any help is appreciated!!
Thanks,
Mike
Old Mar 10, 2002 | 12:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've got TPIS large tube runners on my engine. They are the exact same as the AS&M large tube runners. I dont know what they flow, however... Flow info is really hard to find, as not many people have had them flowed, and the companies want to keep that info secret, of course.
The vortec base comes setup to match the Vortec heads and stock runners. If you port both the heads and intake, and use aftermarket runners, they will flow really well. My dad ported his, but I dont have pictures of it yet...
Old Mar 13, 2002 | 04:43 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thanks for the response Kevin. However I'm still stuck in deciding on a base! Right now if I keep the fast-burns, I'll have to stick with the SD Vortec base, even though the general concenses is that it doesnt flow all that well and it's a nightmare to port it due to the injector boss'. If the Accel base flows the best "out of box" then I will choose a different head like the new Dart pro-1's (318cfm out of the box) or maybe a pair of AFR 195's. I need to have the intake flowing 260cfm or so to the heads (bare minimum). My ported fast-burns flow 282cfm @ .550 lift. Please keep more info coming as I will be purchasing a base very soon!!
Thanks again,
Mike
Old Mar 13, 2002 | 05:56 PM
Jim85IROC's Avatar
I'd look into the AFR 190s before the 195s. I was surprised to find on their website that they both flow the exact same numbers (within 1 or 2 cfm), and I think that with equal flow, the smaller runner will help preserve low end power a little better.
Old Mar 16, 2002 | 10:57 AM
Beefy89's Avatar
Anyone seen any flow numbers on the new Holley Stealth Ram?
Old Mar 16, 2002 | 12:02 PM
Jim85IROC's Avatar
I've heard 300 CFM per runner, but because of the runner length, it should still develop its power at a lower RPM than the miniram. Win-win as far as I can tell.
Old Mar 18, 2002 | 06:11 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The Holley Stealth ram base wont work with the stock style upper plenum and runners, will it?
Old Mar 18, 2002 | 06:22 PM
Beefy89's Avatar
It has a plenum on it.Looks kinda like the MiniRam.....
Old Mar 18, 2002 | 08:49 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
For base, the TPIS BM. Or u could buy an Edelbrock and port it yourself.
Old Mar 20, 2002 | 03:39 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
IROCZTWENTYGR8 - doesn't the Accel base flow more than the TPIS base?
Old Jan 2, 2006 | 11:11 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
How about this:
http://dtcc.cz28.com/flow/index.htm
This shows that the 48mm TB flows 783/822 CFM wo/w an airfoil, while the 52mm TB flows 849/899 wo/w an airfoil.
Sorry, I did not mean to post this under this thread, but the other one. I dont know how this happened.
Old Jan 2, 2006 | 03:57 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I have seen the SLP and Edlebrock runners side by side . I can say the SLP is visually smaller diameter. So I'd say the Edlebrock flow more ( unported)
Old Jan 2, 2006 | 04:52 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
all the dimensions for after market bases,and runners are listed in the FAQ section of the homepage. The Accel,Edelbrock,TPIS bases all have the exact same dimensions....
Old Jan 2, 2006 | 06:22 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It's a few years too late, but FYI the vortec heads can be modified to accept about any of the older design sbc intakes.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Steve78LT
Feb 24, 2016 12:15 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
