EGR Kit from SDPC
Old Apr 21, 2005 | 03:30 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
EGR Kit from SDPC
Finally got the engine out of the crate today and on its stand. Got a chance to open the remote mount EGR kit from scoggin dickey. All is was, was a bunch of TPI plenum gaskets, 2 tubes, and some more gaskets. WTF i paid 70 bucks for this.
There is one long tube, in the shape on an elongated V, about 12 inchesin length, with flanges on both sides...then the shorter tube is basically a flang with a 45 degree tube on it, about 6 inches in length. The longer tube has a fitting drilled into it, for what i dont know yet. I called scoggin dickey and asked why no instructions were in the kit, and the guy on the phone had a hardcore texan accent, said "yeeea thats because its a universal kit, are you running headers?" and i said yes...he said "yea youve got to basically drill a header and then run it to your EGR valve." um ok.
no clue how to do this, supposedly the intake base plate seen here:
has no EGR port in it, which is why I need the install kit
can someone give me a better idea of what to do?
Old Apr 21, 2005 | 07:32 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Look by the distributor hole... Thats where it goes into and in the middle of the intake is where you bolt the actual EGR valve to.
Kat
Old Apr 21, 2005 | 07:35 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
sorry should have edited.
i need to know how to get the tube into the exhaust. its not the intake that doesnt have the EGR provision...its the heads. vortec heads have no exhaust crossover. one idea was to tap the y-pipe and go from there...i dont know though.
Old Apr 21, 2005 | 07:36 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Just tap into the #8 primary. You'll prolly have to get a bung wleded onto it tho.
Kat
Old Apr 21, 2005 | 07:37 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
is there anyway to do that without messing up the coating on the header?
Old Apr 21, 2005 | 07:38 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Nope, not that I know of.
Kat
Old Apr 21, 2005 | 07:43 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
f that then. my y-pipe's coating is gone...my headers isnt...ill tap the y-pipe and put a low pressure EGR in. then ill be good to go i suppose.
Old Apr 22, 2005 | 05:15 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Can you post a pic after you get this set of egr tubes on?
I have corvette heads and what looks like that same base...EXCEPT; I only have the egr bolted on the intake and a cover covering the hole near the dist. Does this mean I have no egr hooked up? I pass smog here in Cali. Hmnn. I have the wire and vacum line hooked up to the egr, but no tube going into exhaust?
Old Apr 22, 2005 | 05:35 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
I think you're ok. it says on SDPC website that it accepts factory corvette applications.
Old Apr 22, 2005 | 05:53 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
anyone can you please post a pic of a vette head set-up. Why are there two tubes in the kit?
Old Apr 22, 2005 | 06:02 PM
Parrydise7's Avatar
Does anybody have a GM p/n for this? Thanks.
Old Apr 22, 2005 | 09:21 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
no Gm part number
the SDPC part number is 3816
their website is sdpc2000.com
two tubes:
one tube is a bung really, that is supposed to be welded into the primary, the other tube connects to that, and basically connects to the rear of the manifold.
Old Apr 23, 2005 | 01:21 PM
postal's Avatar
Engine: hampster in a wheel
Transmission: 700r
the part that comes from sdpc is actually a gm part .It is the exhst egr tube from the vette .I use that base and when I ordered the kit it was the same piece from the vette with a gm tag on it .I work for gm coulda got it for much cheaper if I had known pipe assm gm pn#10055728
Old Apr 23, 2005 | 04:09 PM
Parrydise7's Avatar
Thanks!
Edit: $47.75 at gmpartsdirect.com (plus shipping)
$69.25 from Scoggin Dickey plus $9.75 shipping for internet orders. For telephone and fax orders, actual cost plus $5.00 handling.
Old Apr 24, 2005 | 12:04 AM
postal's Avatar
Transmission: 700r
no worries at least u can save some money!
Old Apr 24, 2005 | 10:06 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I guess I will just leave mine on for visual..don't feel like welding on the headers. funny though....8years and am just finding out the dam egr was never functional; hmmmnn
Old Apr 24, 2005 | 10:13 AM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
can someone give me the heads up on how to block off the EGR passages on the baseplate? my tuner says i can just get rid of the EGR...and he can tune me to pass emissions.
Old Apr 24, 2005 | 11:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is a pic of mine:
Old Apr 24, 2005 | 10:14 PM
postal's Avatar
Transmission: 700r
If you have a vette or sdpc base you can buy block off plates where the exhst is plumbed in .If u have a stock base you can just leave the egr in place and just keep the vac line off it and it will just stay closed and not function.
Old Apr 25, 2005 | 12:06 PM
dyeager535's Avatar
Car: Which one?
Transmission: 465
I'm using the SDPC kit, and it looks similar to dyno dons. The Corvette pipe has a hole in it that I used for the EGR temp switch. Seems to work, not throwing any codes. My EGR valve doesn't have the port for the temp switch, so that port worked great in my case.
Had to ruin the coating in the headers where I welded it in. I say ruin, but actually it isn't really anything other than discolored. I know welding it voided the header coating warranty, but it still isn't rusty or anything and I didn't paint it afterwards.
I used more of the metal pipe that is welded to the headers than dyno don, to route the flexible pipe BEHIND the valve cover to get the cover off without having to unbolt the EGR stuff. Didn't exactly have enough space to make it work as easily as I had hoped, but I've pulled my valve covers a few times without removing the EGR stuff.
From what I saw, it looks like the pipe (or two) from a 2.8L Camaro could be made to work. Really common in the wrecking yards. I *think* it will seat against the SDPC intake ok, (might need to grind the edges of the pipe seating surface a bit to fit) just have to come up with a way to hook that pipe to your exhaust.
Personally, I know that even if I got the Corvette pipe for free, the time spent getting the right materials, and the effort, time, tools needed to create that metal header piece would exceed the $70 the kit cost. (thats only if you plan on using the entire SDPC kit as it comes) It just wouldn't be worth *my* effort/time to try and replicate the piece someone else has made. (thats not meant to mean I'm better than that, just that I know that my projects invariably take 10 times more money, effort and time than planned) Plus you get some gaskets and bolts you'd have to buy as well. (which admittedly are cheap, but more things you'd have to drive to the store for, hassle with the counterperson, etc. )
Of course, I'll spend days working on building/modifying something I could probably buy for $20, but it comes down to whether or not what's out there suits my needs exactly or not.
Old May 5, 2005 | 07:14 PM
Parrydise7's Avatar
Aren't they exactly the same?
Edit:
Hey Don (or anybody else that wants to answer)!
Would this egr set up work on an HSR?
Old May 5, 2005 | 09:32 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
The HSR doesn't have provisions for an EGR.
Old May 7, 2005 | 01:46 PM
dyeager535's Avatar
Car: Which one?
Transmission: 465
His installation and mine just look different the way we routed them, that's what I meant.
Old May 7, 2005 | 02:15 PM
Parrydise7's Avatar
I sent an inquiry to Holley to find out why they don't make a smog-legal HSR. I'm still waiting for a reply.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Kenwood
Sep 11, 2015 12:50 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
rjcme
Sep 5, 2015 01:23 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
