Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
side exit exaust
Old Nov 24, 2002 | 09:16 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
side exit exaust
does anyone have a pic or a few of side exit exaust on a 3rd gen...im thinking about doing this because my exaust is rubbing against my rear end now...(4 inch exaust)
any help and pics would be great..
thanks
iroc2nv
edit..1000th post...woooo hooo
Old Nov 24, 2002 | 09:24 PM
darbleinad's Avatar
Car: 84 Trans Am
you have 4inch exhaust on a stock/relativley stock 350? good *** man, what on earth for....thats expensive stuff. i thought you had a hooker cat back?
Old Nov 24, 2002 | 09:26 PM
darbleinad's Avatar
Car: 84 Trans Am
oh do a search on the subject...there is a picture of a car like easyspeeds with side exit exhaust. at the risk of getting my assed flamed i think side exit exhaust looks pretty good...however ground clearance will be an issue
Old Nov 24, 2002 | 09:40 PM
Stang Eater's Avatar
what are you thinking brad???? side exit looks like ****!!!haha j/k
Old Nov 24, 2002 | 09:41 PM
darbleinad's Avatar
Car: 84 Trans Am
bwhahahaha.......flame on......hahahaha
Old Nov 24, 2002 | 10:16 PM
Slade1's Avatar
Side exhaust coming out of the ground fx themselves?
I always wondered how that would look like..
You'd nail the ground clearance issue, but it would require some reworking of the floor pan design.
Old Nov 24, 2002 | 10:55 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
before i went true dual, i had mine come out of the passenger side before the rear wheel, no problems with clearance i got be a square tip, and it looked pretty good, now the only thing that bothered me and made me change it was the noise especially at highway speeds...wow....but no reworking of the floor pan it actually looks like it was designed for it.
Old Nov 25, 2002 | 05:40 AM
nblanchard's Avatar
Idle, you wouldn't have to rework it, because the passenger side was made for the exhaust... its the drivers side that's tricky.
I was watching "Popular Hotrodding TV" yesterday, and they had a 3rd gen Camaro on there with side pipes, from up top, it looks nice, but it did hang down a bit... Here's some pics for true duals ona 4th gen http://pages.sprint.ca/modpics/files/3dualalb.htm
Old Nov 25, 2002 | 09:41 AM
Demon355's Avatar
I have true dual as well on my bird. Except my exhaust stops at the rear axle and curves downward a bit. Not a bad ground clearance problem. I think the side exhaust would look awesome!
Old Nov 25, 2002 | 11:46 AM
johnyIROC's Avatar
Unless you have access to a plasma cutter, a good welder, alot of time and a general understanding of WTF you are doing, you can pretty much forget about routing it through the GFX.
Iroc2nv: Do you have 4" off the collectors or 4" tips, because there is a BIG difference.
Old Nov 25, 2002 | 04:56 PM
Acceld Z's Avatar
Car: 1992 Z28
Re: side exit exaust
thanks
iroc2nv
Got a part # for that 4" Hooker exhaust? I'd like to get one and it should be inexpensive.
What the hell do you need a 4" exhaust for?
Old Nov 25, 2002 | 07:33 PM
iroc2nv's Avatar
Axle/Gears: 3.45
nope it was the one that i ordered from jegs... it could be smaller but i dont think so...
i am thinking about having noize boyz do the exaust up and see if they are interested in sponsorship...
iroc2nv
Old Nov 26, 2002 | 04:22 PM
Z-drr-Guy's Avatar
iroc2nv
You probly got the 3" .....it just looks like 4"
Old Nov 26, 2002 | 04:32 PM
darbleinad's Avatar
Car: 84 Trans Am
yeah, unless hooker is hiding it they dont make a 4 catback....and 4 catbacks are very expensive.
Old Nov 26, 2002 | 06:08 PM
iroc2nv's Avatar
Axle/Gears: 3.45
ok..then its the 3 inch one....but i think it may be for sale....i am seriously looking into this side exit exaust thing...
just a matter of seeing if it will work and if i will not have burn marks in my skirts
iroc2nv
Old Nov 26, 2002 | 09:45 PM
johnyIROC's Avatar
iroc2nv
Are you planning on running the pipes inside of the GFX for the length of the car?
Because in case you don't know... underside of the car hangs down further than the GFX. You are going to have to channel the floor.... not amateur stuff.
If you just want side exit under the GFX and aren't worried about clearance... it's no big deal.
Old Nov 27, 2002 | 05:29 PM
Acceld Z's Avatar
Car: 1992 Z28
iroc2nv
I'll bet you have all kinds of burn marks on your skirt
Old Nov 27, 2002 | 06:25 PM
iroc2nv's Avatar
Axle/Gears: 3.45
no..run it(exaust) down as close as possible then just put the tips out of the ground fx...not sure if it will work...but im gonna see
iroc2nv
Old Nov 27, 2002 | 08:43 PM
johnyIROC's Avatar
iroc2nv
Unpossible.
Have you ever even been under you're car?
Old Nov 28, 2002 | 05:56 PM
iroc2nv's Avatar
Axle/Gears: 3.45
yeah many times...i know the pass.. side is easier but i think that the drivers side has enough room as well...itll be trial and error of course...oh and my undercar lights will have to go as well...
iroc2nv
Old Nov 28, 2002 | 06:16 PM
darbleinad's Avatar
Car: 84 Trans Am
removing the under the under car lights would be an excellent mod. as for the duals, go with dynomax bullet mufflers, they flow awesome and will give you the most clearance
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
sbrandon
Sep 9, 2015 07:31 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
